E Fans - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 07-05-2012, 10:56 PM Thread Starter
E Fans
Has anyone installed e fans and what was their experience afterwards? Is it worth it for power gains or just at high rpm?
post #2 of 13 (permalink) Old 07-05-2012, 11:18 PM
Frees up a hair of horsepower due to less spinning mass on the engine.
Get a good fan controller and it will be great
post #3 of 13 (permalink) Old 07-06-2012, 12:05 AM
maplesyrup's Avatar
I have had mine on for a while now, love them. I am not sure of the power gains, but just the space in the engine is almost worth it for me lol! Helps the AC quiet a bit, but not like we get scorching heat over here.
maplesyrup is offline
post #4 of 13 (permalink) Old 07-06-2012, 12:20 AM
here is the best controller there is. its what i use, and hundreds if not thousands of lightning /harley guys
madmike
post #5 of 13 (permalink) Old 07-06-2012, 12:21 AM
i pieced together a kit. mustang fan and mounted in stock shroud. just like mad mike sells
post #6 of 13 (permalink) Old 07-06-2012, 12:34 AM
Definitely worth it. Like Blair said the controller is the key
post #7 of 13 (permalink) Old 07-06-2012, 08:05 AM
KIETH F150's Avatar
I did the e-fan mod on my 2000 f150, I picked up a 19" fan at a junk yard for $50, made my own mounting brackets. With the controller you want to be able to adjust the on/off temp. The controller I used had set temp so the fan ran more then it needed to. Yes I liked it and so did Ford the truck now come stock with e-fans. !!
2012 XLT F150 (Sterling Grey)
Window Visors, Fender Flares
KIETH F150 is offline
post #8 of 13 (permalink) Old 07-06-2012, 03:46 PM
I got the mustang fan off rockauto for 100$. The fan controller was like 125$. Should be able to save 250 in gas inno time with this mod
post #9 of 13 (permalink) Old 07-06-2012, 11:00 PM Thread Starter
Thanks for the input guys. Really appreciate it. You know how it goes----too many ideas and too little $$$$. Maybe next year for towing.
post #10 of 13 (permalink) Old 07-07-2012, 11:23 AM
Great for the A/C. Good for the cooling system. Supposed to get about a 5~7 hp gain. As for control, check with f150phule. I gave him the schematics for controlling a dual fan setup. Draw on the altenator is a lot more. You may want to up the output. Heavy gauge wiring and good connections are a must. Definately put heavy relays between the controller and the fans. And fuse everything!
NEED HELP: E-Fans BIGPHIL F-150 2004 to 2008 Forum 6 02-13-2010 06:58 PM
E-Fans littlebronc F-150 2004 to 2008 Forum 5 07-08-2009 04:52 PM
E-fans what do you have and how do you like it? fordtough.ca Truck/SUV Talk 1 04-10-2008 01:20 AM
