NEED HELP: 4x4 lights dont turn on? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 10-29-2012, 05:28 PM Thread Starter
Hey guys,
Just want to say i am new to the fourm.My names Christian and i drive a 2006 F150 xlt 4x4
It recently snowed here ( Edmonton AB ) and i wanted to make sure the 4x4 worked before we got more snow
I switched the 4x4 switch to 4hi and the light on the dash flickered on for 1 second then stayed off
I waited a couple seconds still nothing
I wanted to see if maybe the light burnt out so i turned in a circle and the truck was grabbing and was hard to turn. ( hard to explain but the turning is different in 4wd )
Put it back into 2wd and did the same turn and it turned easy
The light didnt turn on either time
I shut the truck off, turned it to the 'run' position and the 4hi and 4lo lights illimanted for a couple seconds and went off with the other lights (doing its start up dionostic )
What would the issue be if the lights not coming on but 4x4 is engaging?
*Edit*
I also forgot to mention, i scanned my truck couple months back as my tranny was shifting oddly and i had a IWE Solonoid Code that came up when i was looking at all the systems. Could this cause the light to not come on but for 4x4 to work?
Ctrain is offline
post #2 of 2 (permalink) Old 10-29-2012, 06:52 PM Thread Starter
Here is a video showing whats going on.
I removed the IWE solonoid and it looked good, also i checked all the lines going to the front hubs and no water was in them
I did a volt and a resistance test on the connector that goes into the IWE Solonoid ( the harness side )
I got 12V of power when it was in 4HI and i got 7.12 ( the setting was set on 20K ) when the switch was set to 4HI
The code i have is C1979-IWE Solonoid Circuit
Here is the video
http://youtu.be/X6x73VSeTBI
Ctrain is offline
Turn signals and hazard lights not flashing on my 2010 Ranger? DavidY Ranger Forum 9 04-10-2011 09:51 PM
