Trans Problem MAYBE???? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 18 (permalink) Old 11-07-2012, 02:21 AM Thread Starter
Hey guys, so I have heard this noise twice now from my truck and was wondering if anyone here has as well...
I was at highway speeds and all of a sudden, it sounds like their is something (like a mudflap) jammed in my tired, that type of flicking noise, but when i slow down it has clunked when gearing down, and then we i stop, it clunked once more..... and the truck has been fine ever since....
Any ideas??
2008 Ford FX4 SCrew Black
2009 Mazda 3 Black
1996 Camaro Z28 White
2008FX4 is offline
post #2 of 18 (permalink) Old 11-07-2012, 02:43 AM
Clunking when gearing down or stopping is usually a sign of a bad ujoint
post #3 of 18 (permalink) Old 11-07-2012, 10:01 AM
I second the clicking like a stone, relates to U-joint.
post #4 of 18 (permalink) Old 11-08-2012, 01:28 AM
Wouldn't hurt to drop the pan and see if its making metal.
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
post #5 of 18 (permalink) Old 11-08-2012, 04:36 AM
maplesyrup's Avatar
ORRRR
It could be your hubs. Winter is here, you should check and replace your IWE actuator, very common. What happens is hubs lose vacuum due to probably frozen line, hubs trie to engage you hear that grinding noise, you slow down, hubs clunk and engage. Happened to me a few times. Replaced my IWE actuator haven't heard it since.
Food for thought.
maplesyrup is offline
post #6 of 18 (permalink) Old 11-11-2012, 09:41 PM Thread Starter
wouldn't it only be the actuator if I was trying to put it in 4x4???
I jacked it up tried to find some play in the u joints, really didn't find anything.... have it booked into ford for Tuesday morning, but seeing how the sound is intermittent, i have very little fate in them.
Question about the front driveshaft, it comes out of the transfer case and then there is a slip yoke i believe, with a rubber around it.... i have found a little play in that slip yoke... nothing substantial, but could that cause it???
Thanks again...
2009 Mazda 3 Black
2008FX4 is offline
post #7 of 18 (permalink) Old 11-11-2012, 10:36 PM
Check the hoses that go to each front hub, the plastic fitting breaks and you get the gringing at road speed and as you slow down it clunks to engage, no you don't have to be in 4x4 to have thise happen it does it during 2wd, my 05 had that problem and Ford replaced everything for free.
post #8 of 18 (permalink) Old 11-12-2012, 06:45 PM Thread Starter
So I took it for a ride today... When it started to happen I switched to 4High,noise stopped, everything was fine.... and nothing happened after.... so that makes me believe it is the hubs/vacuum system. Bringing it to ford tonight.
2009 Mazda 3 Black
2008FX4 is offline
post #9 of 18 (permalink) Old 11-12-2012, 09:39 PM
maplesyrup's Avatar
Yup exactly same as mine was, the old IWE module or whatever was shitty by design, bought a new one and voila (funny Ford parts guy was like these and the window regulators are selling like hotcakes! :/ ). If yours has warranty I am sure they will replace it.
post #10 of 18 (permalink) Old 11-13-2012, 12:10 AM Thread Starter
No warranty left. Also I thought they fixed the issues with the solenoid by 2008. Well now I know it's either the solenoid or actuators or maybe a shitty hose. Lol. Going into the shop as we speak. I would be fixing it myself except I got work tomorrow for 7 days. 16 hour days, and I need my truck for my first day off next week. I guess I'm stuck paying the 210$ per hour labor fee................
2009 Mazda 3 Black
2008FX4 is offline
trans temp.gage hoss F-150 2009 to 2014 Forum 4 05-07-2011 12:47 AM
Trans cooler swackly F-150 2004 to 2008 Forum 0 03-20-2010 09:18 AM
Troyer Trans Cooler 06KingRanch Driveline and Transmission 4 06-15-2009 12:32 PM
NEED HELP: Trans crossmember rickwest Driveline and Transmission 2 11-15-2008 05:41 PM
