5.0 swap? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 17 (permalink) Old 02-20-2013, 03:36 PM Thread Starter
5.0 swap?
Anyone do it? If so what's involved it would be a lot more powerfull then the 5.4
T_RAT is offline
post #2 of 17 (permalink) Old 02-20-2013, 04:19 PM
have fun. Easy if you've got a complete donor truck with all wiring, ECU, etc etc etc
post #3 of 17 (permalink) Old 02-20-2013, 05:31 PM
Why would you go back in time ?
And have fun trying to get a E test as well
post #4 of 17 (permalink) Old 02-20-2013, 05:34 PM
I think he means a 2011+ 5.0, but either way it wouldn't be easy.
post #5 of 17 (permalink) Old 02-20-2013, 07:09 PM
etest would be the easy part. Since the 5.0 wasn't offered out of the factory in the truck it would be run as a "modified" or in other words "hot rod" vehicle. No need to pass the etest just run it under conditional. Problem is if he sold it later the next owner would have huge problems getting it on the road
post #6 of 17 (permalink) Old 02-20-2013, 07:20 PM Thread Starter
Yea I'm talking the new duel overhead cam coyote 5.0 definately would not go back in time with a pushrod 5.0
T_RAT is offline
post #7 of 17 (permalink) Old 02-21-2013, 07:38 AM
On the contrary, it would still need to be etested. Just it gets tested against higher limits.
I've seen a couple coyote 5.0l engines with full wiring harnesses on kijiji.
Def gunna be some challenges. Things like the message center. Transmission sensors. Bcm to PCM talk. Vehicle anti theft. Even allowing the truck to start.
You might need someone who can crack the programming of the coyote engine and reprogram it, taking out some of the problematic stuff.
Why not just drop a S/C on yours? Cost about the same $. But you'll have more power. Especially low end.
5.0l is a high rpm engine. 5.4 is a lower torque power engine.
post #8 of 17 (permalink) Old 02-21-2013, 08:47 AM Thread Starter
Ok talking superchargers then can you bolt on a eaton from a lighting or or older Harley truck?
T_RAT is offline
post #9 of 17 (permalink) Old 02-21-2013, 09:14 AM
That all depends on what year your truck is? Eaton can be made to work on a 2 valve 5.4L but not a 3V 5.4. If you have a 3V 5.4 there are lots of S/C options out there that will get you to around 450hp and 500ld/ft.
post #10 of 17 (permalink) Old 02-21-2013, 03:09 PM
trust me no limits, how do you think I got my F150 done? You run it the 1st time it fails, you get estimate on what it'll take to get it to pass (more than $400 and you don't have to get the work done) then you run it second time for conditional. Been doing mine this way for the last 8yrs
anyone gotten into a 4.6 swap? FX4Ranger Ranger Forum 11 05-14-2012 08:56 PM
4.6 -4.6 engine swap littlebronc Gas Engines 10 06-18-2009 11:09 AM
90 to 94 Body Swap Henry Ford F-150 Pre-1997 Forum 7 05-18-2009 06:53 PM
Engine swap? bluegoose Diesel Trucks 5 04-23-2009 02:44 PM
Swap Meet Smokefan Ontario 7 08-14-2007 08:07 PM
