Power Door Locks - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 03-27-2013, 11:14 AM Thread Starter
Power Door Locks
Having trouble with the power locks on my 2004 , sometimes they work from the remote, sometimes they don't. Sometimes it takes 4-6 pushes on the door switch to get the passenger side to unlock. I have tried to lube from the top but that dosen't seem to help. Anyone have any experience with them, do I need to change the whole door lock / striker mechanism, I had the driver side panel off and it looks like a complete unit ?
tractorguy is offline
post #2 of 12 (permalink) Old 03-27-2013, 11:49 AM
Manford's Avatar
I had issues with the window switches. I removed the switches and took them apart and slid a finger nail file between the contacts and it cleaned off the carbon that was affecting the contact surfaces. I would imagine that the lock switch is the same.
If you take the key fob apart there is a contact disc that is dished. When you push the button it invert the small copper disc and completes the connection. Several times I had to "Re-profile" them (for lack of a better description). I did this by cradling the disc on my finger and gently pushed down in the centre of the disc with a ball point pen. Then I tried to re-introduce the dish with even pressure up on the perimeter. It is very easy to kink or fold the disc so you have to be very gentle.
__________
ManFord
Manford is offline
post #3 of 12 (permalink) Old 04-06-2013, 02:51 PM
Mechanic
OFD#17's Avatar
Also check inside the rubber boot thing where all the wires go from the door to the Cab, both my door unlock wire, and window for ft passenger wire were broke. i had to do some splicing of wires to bypass the part that snapped.
05 F150 FX4 SCAB
AFE Stage 2 CAI, EDGE Evolution CS, HD Tail and Headlights, Rough Country 2.5in leveling lift, Cooper AT3 tires, Saleen Grille, HID heads and fogs
OFD#17 is offline
post #4 of 12 (permalink) Old 04-10-2013, 04:02 PM Thread Starter
Thanks for the answers , heres something that I haven't found yet , on a exteneded cab wheres the switch for the interior light ? Remember the old days when it was on the door post. I have had issues with it also, seems to freeze in the winter.
post #5 of 12 (permalink) Old 04-10-2013, 04:33 PM
Manford's Avatar
It is part of the latching mechanism, WD40 is your best friend.
__________
ManFord
Manford is offline
post #6 of 12 (permalink) Old 04-11-2013, 11:00 AM Thread Starter
Would having my truck RustChecked every year cause oil / dust to build up on mechanism and be causing lock and switch problems ? Maybe I should pull door panels and clean them with wd40.
post #7 of 12 (permalink) Old 04-11-2013, 03:57 PM
Manford's Avatar
These stuck on my 97 Ranger. I just sprayed the lock mechanism and open and closed the door until it gets all lubed. Don't do any more work that is necessary. This is an easy fix for you.
__________
ManFord
Manford is offline
post #8 of 12 (permalink) Old 04-11-2013, 05:14 PM
Originally Posted by Manford View Post
... until it gets all lubed. Don't do any more work that is necessary.
That's what she said.
Sorry....couldn't resist.
post #9 of 12 (permalink) Old 04-11-2013, 07:13 PM
hogdust's Avatar
She looks well abused
2019 RAM 1500 Big Horn Northern Edition - Patriot Blue Pearl
Tri-Fold Tonneau Cover - Flowmaster 10 Muffler - Tint - Side Steps - Bedrug - 20x9 Fuel Beast Wheels - TrailFX Bull Bar with Light Bar
hogdust is offline
post #10 of 12 (permalink) Old 04-11-2013, 09:42 PM
Don't know about abused but well used!
Blend Door LayinHp Super Duty Forum 4 12-20-2010 09:58 AM
NEED HELP: DOOR HINGES big-papa F-150 Pre-1997 Forum 3 06-01-2010 02:38 AM
Door Hinges JimyB Sticky Tech/How to Section 14 04-09-2010 12:12 AM
Automatic Door Locks ? Turbodieselhog Ranger Forum 6 02-20-2008 08:19 PM
