New used F150 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 04-22-2013, 09:20 PM Thread Starter
New used F150
Hello all.
I had an 98 F150 XLT 4x4 That got totaled at an intersection a week ago last Wednesday. In Ottawa. Very sad as I have owned it for 13 years.
I went so see a friend of mine who is a salesman at the local Ford dealer, he sold me the 98. And I checked the prices on new trucks. I find the costs eye watering. 30 K for a reg cab 4x4!!
But, they had just got in the night before a trade in, 2007 XL 5 speed standard 8 ft box, bare bones but with only 15,480 KM !!!! on it, owned buy and elderly gentleman bought and serviced at that dealer. This is a brand new 2007.
So I bought it on the spot for $10,688.66 all in and on the road and a full tank of gas. I picked it up on Saturday morning, and am very happy with it. I checked it out all over and under and it is mint. The oil on the dipstick is so clear, can hardly see it, and its not due for an oil change for another 2000 KM,
So the motor is a 4.2 V6. I an not really that familiar with these motors. I know the 98 foibles like exhaust manifolds cracking and brake rotor replacing issues, very difficult to get off.
Are there any issues I should be aware of on the 2007?
I have read that the motor is a bit of a dog, but I am not looking for uber power, just a good truck, like my dearly departed. I will miss the 4x4 though.
Thanks, Ernie.
Ernie1956 is offline
post #2 of 7 (permalink) Old 04-22-2013, 10:55 PM
1white08fx2's Avatar
With my '06 i use to have, i had no issues at all, and hoping the same with my '08.
Here is the TSB's on the '07.
Technical Service Bulletins
Year: 2007 MODEL: F-150
07-1-7
• MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
06-26-1
• MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-25-15
• ALUMINUM BODY PANELS - CORROSION - SERVICE TIP
06-25-5
• 4.2L HIGH IDLE - INITIAL START UP
06-25-3
• PIONEER NAVIGATION RADIO - SEEK FUNCTION INOPERATIVE - SERVICE TIP
06-23-6
• NOISE FROM BACK GLASS - POWER SLIDING REAR WINDOW ONLY
06-21-19
• HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)
06-21-7
• AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-19-16
• SHUDDER/VIBRATION ON MODERATE TO HARD ACCELERATION
06-18-15
• IGNITION DIAGNOSTICS
06-17-8
• SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
07-2-6
• POWER WINDOW SLOW UPWARD TRAVEL
07-4-3
• LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
07-5-8
• BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
07-6-5
• LOBO - REAR AXLE TUBE FRACTURE AT CENTER CARRIER (MEXICO ONLY)
07-10-9
• VIBRATION FROM THE DRIVELINE AT HIGHWAY SPEEDS
07-12-1
• POWER SLIDING REAR WINDOW MOTOR REPLACEMENT
07-12-3
• RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS
07-16-13
• WRENCH LAMP ON - DTC P0731 - 4.2L AND 4R75E ONLY
07-16-17
• SPARK KNOCK UNDER LIGHT LOAD AND ACCELERATION - 3.8L, 3.9L, AND 4.2L - SPLIT PORT INTAKE MANIFOLD RUNNER CONTROL (IMRC)
07-21-2
• 4.6L 2V, 5.4L 2V, OR 6.8L 2V - SPARK PLUG THREAD REPAIR PROCEDURE - NOT COVERED UNDER NEW VEHICLE LIMITED WARRANTY
07-21-3
• HIGH PRESSURE POWER STEERING LINE SEEPAGE - COLD CLIMATES ONLY (EXCLUDING HERITAGE F-150)
07-22-7
• PAINT - INSTRUMENT PANEL - SCRATCH/MAR REPAIR TIPS
07-24-3
• COLD START ROUGH RUNNING/HESITATION/BACKFIRE - 5.4L ONLY
07-24-7
• A/C COMPRESSOR SHUTOFF - HIGH AMBIENT TEMPERATURES - VEHICLE STATIONARY IN GEAR
07-24-8
• ENGINE MISFIRE DURING CRUISE WITH OR WITHOUT DTCS (MEXICO ONLY)
07-25-2
• TAILGATE STRIKER - NOISE/RATTLE
07-25-13
• FRAME REPLACEMENT MATRIX - SERVICE TIP
08-2-9
• ERRATIC FUEL GAUGE OPERATION - MIL ON - DTCS P0460/P0463 OR INSTRUMENT CLUSTER MODULE DTC B1201 - VEHICLES BUILT BEFORE 12/3/2007
08-4-3
• MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) - P0456
08-4-4
• COLD START ROUGH RUNNING/HESITATION/BACKFIRE - 4.6 ONLY
08-7-6
• SPARK PLUG REMOVAL INSTRUCTIONS - 4.6L 3V/5.4L 3V/6.8L 3V
08-8-9
• GRINDING NOISE FROM CLIMATE CONTROL - CHANGING AIR DISTRIBUTION MODES - BUILT AFTER 11/29/2005
08-11-1
• INTERMITTENT VEHICLE VIBRATION - PARKING BRAKE DISENGAGEMENT CONCERNS
08-12-1
08-12-9
• INOPERATIVE RKE TRANSMITTER (KEY FOB) - DISCHARGED KEY FOB BATTERY
08-14-3
• 5.4L 3V / 4R75E ONLY - BUILT BETWEEN 12/4/2006 TO 5/20/2008 - ENGINE RPM FLARE DURING 3-4 UPSHIFT UNDER LIGHT THROTTLE ONLY
08-14-6
• HARLEY-DAVIDSON SUPERCHARGER / EXHAUST CATALYST RATTLE
08-21-11
• 4 WHEEL DRIVE/ALL WHEEL DRIVE - WITH CONTROL TRAC - SHUDDER ON ACCELERATION/DECELERATION OR BINDING ON SLOW TURNS
08-23-6
• EATC - INTERMITTENT WARM AIR OUTPUT TEMPERATURE SET 68-72 F (18-22 C)EMTC - INABILITY TO CONTROL TEMPERATURE OUTPUT
08-24-2
• VIBRATION DIAGNOSTICS - STEERING WHEEL NIBBLE - TIRE WHEEL RUNOUT AND BALANCE
08-24-8
• WATER LEAKS - ROOF OPENING PANEL DURING HIGH PRESSURE CAR WASH
08-25-5
• DRIVERS SIDE COWL PANEL POPPED-UP
09-9-7
• COLD START FEAD HOOT - WHISTLE NOISE
09-20-14
• UN-COMMANDED TCC APPLY ON THE 1-2 SHIFT CAUSING PERCEPTION OF HESITATION AND/OR LACK OF POWER DURING SHIFT
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #3 of 7 (permalink) Old 04-23-2013, 08:42 AM Thread Starter
Wow, that is a lot of TSB`s my other vehicale (VW) had only 3.
Thank you for the info.
Ernie
post #4 of 7 (permalink) Old 04-28-2013, 09:56 AM Thread Starter
Unintended acceleration
Am I ever glad I did not get a 5.4 motor they really seem to have alot of issues.
I have done some poking around on other sites and found a repair complaints web site about unintended acceleration of the Fords. Has anyone heard of this problem, it is mentioned on, carcomplaints.com
My truck is a 5 speed standard and I have hit the brake and gas at the same time by mistake twice, just me not moving my big foot over the brake pedal far enough. I am wondering if this is typical. I have done it several times in my sports car as well but there is really not alot of room at the pedals, thats my excuse anyway.
Has this happened to anyone else and or know anything about the issue?
Thank You Ernie
P.S. I did a search and nothing came up.
post #5 of 7 (permalink) Old 04-28-2013, 10:29 AM
post #6 of 7 (permalink) Old 04-28-2013, 11:07 AM Thread Starter
I think I might have kicked a hornets nest.
I checked some more on the other Ford sites and it seems to be driver issues.
Its just my big foot syndrome.
Ernie
post #7 of 7 (permalink) Old 04-28-2013, 08:32 PM
The later 5.4's don't have the same issues as the earlier 5.4's. I did a lot of research before i bought my '08 with the 5.4L. I really didn't want that dreaded spark plug issue! After late '07, they had the redesigned head with the one piece plug. Another way to tell is the the later 5.4's had brown top coil on plugs.
As for the issue you are takling about, in my opinion. Driver issue LOL!
aka 1LOW03GT
2010 F150 or 2011 F150 benyl F-150 2009 to 2014 Forum 29 09-18-2010 11:06 AM
