Front diff service - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 19 (permalink) Old 04-28-2013, 01:32 AM Thread Starter
Front diff service
About a month ago I drained the front diff and put on a new cover complete with gasket. What a PITA it was to get the diff cover off and back on again! Anyways, I used the gasket and rtv`d the pumpkin around the bolt holes. I also put locktite on the bolts when I reinstalled. I let the rtv sit for about 15min after install before I filled with the new gear oil. My problem is that about 2 weeks ago I noticed the front diff weeping. When I crawled under the truck The bottom 5 bolts had loosened off and oil was seeping out of them. It also appears to be leaking from the very bottom of the gasket. I thought this was a straight forward service, and am a little confused why it took 2-3 weeks to leak and now I can`t seem to stop it. Anyone have any tips for when I pull the cover and reseal it again? I only want to do this one more time. Thanks guys!
post #2 of 19 (permalink) Old 04-28-2013, 01:34 AM Thread Starter
Should also mention that I used brakecleaner to clean the pumpkin AND I scraped off the old rtv.
post #3 of 19 (permalink) Old 04-28-2013, 08:38 PM
1white08fx2's Avatar
So i am undestanding this correctly, you used a gasket, not a RTV sealer on the perimeter, only around the bolt wholes.
I myself have always only used rtv sealer around the whole perimeter, and never used an actual gasket, and have yet to expirience a leak.
But, if a gasket is being used, a "sealer" is still needed to help it "stick/bond" so it can seal properly.
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #4 of 19 (permalink) Old 04-28-2013, 09:26 PM
TRNRBILT's Avatar
I've always put the gasket maker on the pumpkin then on the cover and then sandwhiched the paper gasket between the two layers. Be sure to go on inside of the bolt holes though so that it won't leak out the threads. Also I've never used lock tight on the bolts just a little bit of the gasket maker on the threads when I put them back in. Haven't had a leak yet. (Knock on wood)
TRNRBILT is offline
post #5 of 19 (permalink) Old 04-28-2013, 11:15 PM
TRNRBILT I've always put the gasket maker on the pumpkin then on the cover and then sandwhiched the paper gasket between the two layers. Be sure to go on inside of the bolt holes though so that it won't leak out the threads. Also I've never used lock tight on the bolts just a little bit of the gasket maker on the threads when I put them back in. Haven't had a leak yet. (Knock on wood)
I was gonna say everything Jay and James said but thats to much typing
post #6 of 19 (permalink) Old 04-28-2013, 11:29 PM Thread Starter
I used the gasket that came with the cover AND put rtv on the pumpkin around the perimeter and the inside of the bolt holes. However I only put the rtv on the pumpkin. I did not use it on the cover as well. I think maybe that is my problem? I only want to do this once more. lol
post #7 of 19 (permalink) Old 04-29-2013, 06:49 PM
Ol Skool's Avatar
I'm with Jay on this one. Skip the gasket, just RTV. The aftermarket gaskets, somtimes will not compress and cause the bolts to loosen.
Gerry
Ol Skool is offline
post #8 of 19 (permalink) Old 04-29-2013, 09:39 PM
That's your issue!! Pull the cover off, and get rid of the gasket, and just rtv it.
aka 1LOW03GT
post #9 of 19 (permalink) Old 04-29-2013, 10:16 PM Thread Starter
Gerry
Thanks guys! I bought 2 more quarts of fluid today and the weather is supposed to be stellar this week. Hopefully I can get it done in the next few days
post #10 of 19 (permalink) Old 04-30-2013, 10:08 PM
Well, i am praying it is nice for you.
aka 1LOW03GT
Rear diff Bruicer Suspension 2 05-14-2010 04:35 PM
Rear Diff Axehandler Driveline and Transmission 1 02-05-2010 04:03 PM
My new diff cover Mar Driveline and Transmission 17 04-05-2009 06:11 PM
Front diff. locker and Ltd. bluegoose Diesel Trucks 1 03-31-2009 11:23 PM
