NEED HELP: Screech when shifting - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 05-21-2013, 08:35 PM Thread Starter
Hammermill97's Avatar
Just wondering if anyone has experienced the following?
My 5.4L is producing a screech sound at the shift points that I originally presumed was the belt, or at least it sounds exactly like a belt slip.
And b/c I thought it was the belt I didn't (haven't) really panicked, I just planned on replacing it whenever I got the chance.
It only tends to do this if I've got my foot into it and shifts at higher RPM's, generally through the first three gears.
Now before I go ahead and replace a belt that I just replaced last summer, I'm wondering if a serpentine belt would actually squawk like that???
I thought I would check here and see if anyone else has had this issue and or discovered its origin?
Or if anyone thinks it could be a tranny issue?
Also, my exhaust is a little too loud to really hear and pin point the location.
Thank you in advance for the heads up
Hammermill97 is offline
post #2 of 14 (permalink) Old 05-22-2013, 12:01 AM
Belt. As a matter of fact, the police crown Vic's did it so bad, they put a one way clutch on the alternator pulley.
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
post #3 of 14 (permalink) Old 05-22-2013, 12:23 AM
Mine does it also but only under wot with tunes.
post #4 of 14 (permalink) Old 05-22-2013, 02:39 PM Thread Starter
Good to know, easy fix for a change :D
If anyone cares, the belt I put on to replace the OEM was a 'Gates' premium
Going back to the Goodyear gatorback I've used on other vehicles and see if that's the fix
Thanks again
post #5 of 14 (permalink) Old 05-22-2013, 04:48 PM
Let us know how the new belt works
post #6 of 14 (permalink) Old 05-22-2013, 05:37 PM
Any annoying screech in a truck can usually be fixed by getting a divorce.
I did this one just because I couldn't stand to see 2299 posts.
post #7 of 14 (permalink) Old 05-22-2013, 06:27 PM
Ol Skool's Avatar
That is a costly fix.
Check the idler pully. If the spring is weak, the new belt will talk to you
Gerry
Ol Skool is offline
post #8 of 14 (permalink) Old 05-22-2013, 10:12 PM
Gerry
If the belt is worn cracking and glossy.. I've seen them squawk as well.
post #9 of 14 (permalink) Old 05-22-2013, 10:19 PM
1white08fx2's Avatar
... or if ones vehicle is backed by a manual trans, and you are shifting over 6000 rpm with the foot to the floor, the belt is know to chirp threw those shifts!!
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #10 of 14 (permalink) Old 05-23-2013, 03:57 PM Thread Starter
Ha Ha, no that's how I drive the wifes car, I would never treat my truck like that...
04 fX4 4wd shifting Problems iohwyswn F-150 2004 to 2008 Forum 7 01-24-2012 11:33 AM
09 Auto Ranger Strange Shifting Blue Oval Driveline and Transmission 0 10-01-2011 07:11 PM
NEED HELP: 09 f150 shifting problems gapperf150 F-150 2009 to 2014 Forum 1 07-06-2010 04:08 PM
Transmission shifting problem lilbruicer F-150 1997 to 2003 /04 Heritage Forum 6 11-13-2009 12:29 AM
Shifting Bliss. canadian.bacon Ranger Forum 21 08-18-2009 10:06 PM
