Heat/cool issue fixed - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 06-28-2013, 05:52 PM Thread Starter
Pretty much had this issue since new..Heat was either full cold or full hot..no in between..lived with it for 4.5 years..Got searching and found it to be the blend door actuator..62 bucks from Ford and i swapped it myself in a couple hours..All is good again..P.S. that back bolt is a PITA..I have small hands and it was a chore to come in from the glovebox to get a wrench on it..But still worthwhile fixing something yourself..No pics cause i was swearing too much
post #2 of 10 (permalink) Old 06-28-2013, 08:13 PM
soooo many comments but I'll be nice this time
post #3 of 10 (permalink) Old 06-28-2013, 09:15 PM Thread Starter
Have at er Jimmy
post #4 of 10 (permalink) Old 06-29-2013, 07:12 PM
1white08fx2's Avatar
Are you talking about the use of the heat cold climate controls?
If i turn the heat down, i turn the dial to the middle, it will still be really hot, so i turn it 1/4 way threw the cold side it will still be hot, but then other times it will be cold like it should on the cold range, or a little cool when i turn the dial just a bit past the middle into the heat side!! Makes it hard to dial in!!! My '06 F 150 didn't do this, it was easy to dial it in, and never had this issue!
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #5 of 10 (permalink) Old 06-29-2013, 07:33 PM Thread Starter
Exactly!!!!!..That's what mine would do...Hot all the way down to the 1/4 mark..Drove me nuts.
post #6 of 10 (permalink) Old 06-29-2013, 09:11 PM
I guess i will have to check into this LOL!
aka 1LOW03GT
post #7 of 10 (permalink) Old 06-29-2013, 09:56 PM Thread Starter
Not to bad to get into..rip the trim and radio out..unplug a few connections and then open the glove box..a 8mm socket..7 mm wrench and a pair of needle nose pliers to put the clips back on the trim..i used a flat screwdriver to reach in to unplug the connector..It's nice putting the dial to middle and not cook..lol..Might be different if you have the automatic air..I have the manual.
post #8 of 10 (permalink) Old 06-30-2013, 12:04 AM
Sounds easy enough. Did a search after seeing your post. Didn't realize how common this issue is. LOL
Gonna play around with mine just to make sure before i spend the moola on one.
Mine are manual aswell.
aka 1LOW03GT
post #9 of 10 (permalink) Old 06-30-2013, 11:54 PM
they are common. glad you got 'er fixed! and be glad that it's not a 1/2 ton with dual automatic climate control. the one that always poops out is the driver's side - buried underneath the entire dash/plenum; the seats, carpet, vents, dash etc etc all comes out. tons of fun.
Varsity Tyler is offline
post #10 of 10 (permalink) Old 07-01-2013, 12:02 AM Thread Starter
Yup..bet that would be a headache..I like my plain jane XLT
rough idle fixed Paul F-150 2004 to 2008 Forum 4 03-14-2013 09:37 PM
NEED HELP: 2007 f-250 No Heat issue smbinc Super Duty Forum 7 08-18-2011 03:56 AM
No heat Fordwheeler Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 9 09-21-2010 10:02 AM
