radio, lock problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 11-16-2013, 07:54 PM Thread Starter
macs07's Avatar
radio, lock problem
This is an 07 FX2 S/crew stock other than an Edge.
Normally when the ignition is turned off the radio will stay on for 10 minutes or untill the d/door is opened. Now the radio will stay on with the ignition off, door opened, closed and locked with the key fob. I have to turn it off manually.
The d/door power d/lock switch is not working. When the vehicle is put into park the d/s and p/s doors unlock but not the rear doors. All the locks work properly with the key fob or the touch pad. The p/side door lock switch works fine as well.
Any ideas???
macs07 is offline
post #2 of 13 (permalink) Old 11-16-2013, 10:34 PM
Sounds like it might be the drivers door pin?
post #3 of 13 (permalink) Old 11-16-2013, 11:09 PM Thread Starter
macs07's Avatar
Is there a way I check to confirm, don't know where to locate the drivers door pin.
macs07 is offline
post #4 of 13 (permalink) Old 11-16-2013, 11:47 PM
TRNRBILT's Avatar
Not sure about the 07s but on the newer 09 up style the door pin is located inside the hinge. Unlike the old vehicles were it was just a pin that got pushed in and out. Travis may chime in on weather or not it is the same setup though because I am not 100% sure.
TRNRBILT is offline
post #5 of 13 (permalink) Old 11-17-2013, 06:23 AM
Quick search lead me to this.
Some quys are saying its in the wiring for the door pin. Either in the sil or door jam boot. Purple wire.
http://www.f150forum.com/f4/need-hel...urn-off-96414/
post #6 of 13 (permalink) Old 11-18-2013, 06:17 PM Thread Starter
macs07's Avatar
Any ideas???
Well little more info on the radio lock issue, the only thing that works on the drivers door is the door handle, no windows, mirrors, locks, exterior key pad, no interior lights.
The window up/down does not work on ANY other door. The radio, interior lights will work off the P/door control, but not the locks or windows.
macs07 is offline
post #7 of 13 (permalink) Old 11-19-2013, 06:01 PM
Possibly ground issue.
I'd be popping the door sil and looking for broken wires, and or rusted out ground wire.
post #8 of 13 (permalink) Old 11-19-2013, 11:08 PM Thread Starter
macs07's Avatar
Thanks for all the info, damaged wire all repaired and working fine
macs07 is offline
post #9 of 13 (permalink) Old 11-20-2013, 12:30 AM
for reference for anyone else with this issue.
which one? and where?
post #10 of 13 (permalink) Old 11-22-2013, 03:05 PM Thread Starter
macs07's Avatar
Sorry, it was the ground (black) in the boot between the D/door and the pillar. Spliced in a length, sodered, taped and shrinked.
macs07 is offline
Power Tailgate Lock lildave F-150 2009 to 2014 Forum 1 05-06-2010 08:44 AM
Remote tailgate lock ricbeau F-150 2009 to 2014 Forum 5 08-26-2009 02:48 PM
Remote Tailgate lock MississaugaRanger Ranger Forum 7 01-30-2009 11:29 AM
Lock Test hogdust Test Section 3 01-08-2009 03:54 AM
Line Lock BapeStaarr Truck/SUV Talk 5 10-30-2008 09:56 AM
