4x4 probs - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 39 (permalink) Old 11-21-2013, 11:27 AM Thread Starter
4x4 probs
Wouldn't you know it, cold, snow and ice and no four wheel drive! Been very icy and lots of snow here for past week or so and -32 with -42 wind chill yesterday morning. Have been sliding around lots and finally noticed last night that my four wheel drive not working. Put it in 4 hi and light comes on in dash but won't kick in. Going to check fuses, relays and IWE solenoid. Any other ideas?
post #2 of 39 (permalink) Old 11-21-2013, 02:53 PM
Welcome to my world. Can you hear the relay in the dash click? I'd throw a new IWE solenoid on it and check the vacuum lines. If you're solenoid doesn't have the rain hood on it like the one on the right its worth the time to change it anyway.
It could ultimately be the IWE actuators at the wheels. Its easy to check those. With the engine off jack up both front wheels up and spin the wheel, the halfshaft should turn as their is no vacuum and the hubs should be locked. If it doesn't turn the actuators aren't working properly and locking.
post #3 of 39 (permalink) Old 11-21-2013, 03:31 PM Thread Starter
Doesn't click. Turn knob to 4 hi and lights up on instrument cluster but that's it. Snowing again and no garage Ryan so will check the easy stuff first.
post #4 of 39 (permalink) Old 11-21-2013, 04:00 PM
If the hubs aren't fully engaging another way to tell is when you engage 4wd while driving it will produce a grinding sound or sound like cards in a bicycle wheel. Hopefully its not the actuators being toast.
post #5 of 39 (permalink) Old 11-21-2013, 06:08 PM Thread Starter
Went out to order my IWE solenoid and do a Timmie's run and as I was waiting in Timmie's drive through I switched to 4 hi and could hear the click in dash and 4 wheel worked. Sure nice to have on these roads! Beginning to think it is the solenoid and just not handling the vacuum properly.
post #6 of 39 (permalink) Old 11-21-2013, 07:11 PM
There is something to be said for manual shift transfer cases.
post #7 of 39 (permalink) Old 11-21-2013, 09:07 PM
TRNRBILT's Avatar
Definetly. I just wish you could still get them in the new trucks still. Without having to get a base work truck model.
TRNRBILT is offline
post #8 of 39 (permalink) Old 11-21-2013, 10:47 PM
I had a similar problem. $15 for the solenoid and 10 min of my time fixed it
post #9 of 39 (permalink) Old 11-21-2013, 10:51 PM Thread Starter
Mine will be in tomorrow morning. Almost twice that price Tim and not even OEM.
Oh well. Supposed to warm up tomorrow so we will see. Still snowing though!
post #10 of 39 (permalink) Old 11-22-2013, 12:49 AM
Mine is a dorman. I got it out of the states. It's super easy to change only 2 nuts. Mine is only held on with one now, I dropped one and never found it lol
NEED HELP: 4x4 issue dranged Ranger Forum 5 01-09-2012 07:20 AM
4x4 ? Justin1635 F-150 2004 to 2008 Forum 13 12-30-2010 02:52 PM
no 4x4 Justin1635 F-150 2004 to 2008 Forum 1 02-06-2010 07:33 PM
4x4 do you have to have it fordtough.ca Truck/SUV Talk 10 08-26-2008 12:29 PM
Has anyone with an 07 4x4 Kirkfry Ranger Forum 21 06-09-2008 01:59 PM
