Transmision help 4.6 2005 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 02-02-2014, 12:11 PM Thread Starter
Hey guys I have a 2005 ford 4.6 with 4 gear tranny when my trucks shifts into 4 th (overdrive) it acts as though nothing is there Rpms shoot through roof and it's like neutral no grinding no nothing just like you slapped it in neutral I am still driving the truck as when you turn od off fourth is elimanated However will still be fixing it if I need a new tranny I can do the work myself and there's a scrap yard here that warranties there transmissions I have 270 km on transmision. Is there a sensor that could be screwing up to cause this??
Thanks ahead
Zach
2005 ford 4.6 wd
Zach is offline
post #2 of 5 (permalink) Old 02-03-2014, 08:47 PM
Broken snap ring in the od servo. Usually ends up in the valvebody blocking the od servo regulator valve. Quick valvebody drop will confirm.
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
post #3 of 5 (permalink) Old 02-04-2014, 07:22 AM Thread Starter
Hey Robert thanks Ron burgandy I will probably have a look at this on Sunday as this is the first day I have off so when I pull the valve body off the snap ring if broken should be there ?
Zach is offline
post #4 of 5 (permalink) Old 02-04-2014, 10:43 AM
Most likely. It's the front servo. I would suggest taking it to a shop to be fixed though. The spring in the servo is a beast. And it's easy for the band to slip out of place
post #5 of 5 (permalink) Old 03-30-2014, 01:02 PM Thread Starter
This problem has been fixed it was the snap ring in there , fluid change and fresh filter were back on the road shifting smothly thanks guys
Zach is offline
my 2005 f250 harley Fukenricen Photo and Video Gallery - Members Rides 28 01-24-2011 10:27 PM
NEED HELP: Hitch (Receiver) on 2005 FX4 garymac221 F-150 2004 to 2008 Forum 3 01-02-2010 01:31 PM
2005 Explorer Noise Question.... Topher Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 5 10-16-2009 06:11 PM
2005 5.4 rough idle and ping fourtirefire Gas Engines 2 01-27-2009 09:27 PM
2005 f350 tires Mise Super Duty Forum 2 11-23-2008 01:49 PM
