Help, not blowing air on any control. Vent, defrost, air conditioner.... - Page 2 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #11 of 21 (permalink) Old 02-06-2014, 08:52 PM
The fan switch is right in your heater control assembly. Unless you have a controller module. Which could also be a possibility.
post #12 of 21 (permalink) Old 02-06-2014, 09:34 PM Thread Starter
Arctic F-150's Avatar
Sorry, might be a dumb ?? but where is the heater control assembly? Or module? Only used to working on snowmobiles. Did a search and couldn't find it on 08 F150.
Arctic F-150 is offline
post #13 of 21 (permalink) Old 02-07-2014, 01:32 AM Thread Starter
Brainfart!! As I was taking the blower motor out I start thinking about it.
Well After I got the motor off I made a connector with wires and connected it to a spare truck battery tested it and the fan started up but kinda slow. So switched wires around and figured was on reverse then forward. Installed blower back on so I can wait for a resistor, took truck out of shop and everything is working fine. Mind you the drive was only about 3/4 mile. Not sure how long it will last like that. Maybe with the truck battery just gave it a short recharge or will it be good from now on? Wondering if I should just order a new blower motor now as shipping to me takes a couple weeks.
post #14 of 21 (permalink) Old 02-07-2014, 08:02 AM
The blower should turn fast in either direction with a good connection. If it turns slow, you may have winding, brush or bearing issues. I would get a blower motor.
post #15 of 21 (permalink) Old 02-07-2014, 11:05 AM Thread Starter
It was pretty fast in reverse just noticeably slower. I will order a new one also. Thanks for all your help Destruction.
post #16 of 21 (permalink) Old 02-07-2014, 09:08 PM Thread Starter
Well after less then an hour of use the blower died again. So got one on order from close by(300+ miles close in the arctic ) should be here in a day or 2 but paying premium. 200+ bucks just the motor no fan. Could've gotten one for just over 100 but wife cannot go without the truck for more then couple days. Bonus though she was asking how much new shocks were for tax season
Now to check out prices.
post #17 of 21 (permalink) Old 02-11-2014, 05:54 PM Thread Starter
It was the blower motor. Got the new one before and changed it. Was about half hour job. Blower motor if any one wondering in the future is right above where the passengers feet go. 3 8mm screws and it is off. Twist motor 90-120* clockwise so you can unplug the connector and so the motor can clear the back wall. A bit of a pain but do not use force or felt like the fan blades would break. Pull motor down then angle it out towards you.
post #18 of 21 (permalink) Old 02-11-2014, 06:34 PM
Glad you found the problem. This is a bad time of year for no heat...lol
post #19 of 21 (permalink) Old 02-13-2014, 10:10 PM
1white08fx2's Avatar
Glad you got it solved!
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #20 of 21 (permalink) Old 11-28-2020, 10:43 PM
Im using a 08 F150 as well, and just want to know if it needs chemical gas overhaul? I dont know much about that term (only heard it in conversation), but it sound pretty important. Went to look it up and it was mostly for this kind of home AC units. Does ford cars need them as well? Thanks!
RunnerRav is offline
Air conditioning Ernie1956 F-150 2004 to 2008 Forum 22 05-14-2013 12:03 AM
NEED HELP: Fan blowing cold air? DavidY Ranger Forum 7 06-13-2012 08:32 AM
Air Compressor SKRWZ Tools 19 08-09-2011 11:36 PM
NEED HELP: heater blowing cold air westcoastranger Interior 18 11-28-2010 11:01 PM
Air Con macs07 F-150 1997 to 2003 /04 Heritage Forum 7 05-28-2009 11:26 PM
