Compass stuck with NW - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-26-2014, 05:42 PM Thread Starter
4X4 EH's Avatar
Noticed my compass on my 2006 F150 FX4 is stuck on NW no matter what direction I am headed.
Everything else 'seems' to be working, odometer mileage is increasing, outside temp 'seems' to be accurate, at least the temp does update.
I was thinking a fuse but can't figure why just the compass and nothing else.
Thought I post here and see if anyone has any ideas.
Only change was a few weeks back I installed a K&N CAI. I did disconnect the battery when I did it, but can't figure how a reconnection of the battery could cause this.
Any one with any ideas??
Thanks.
2003 Mach 1
2012 Shelby GT500
4X4 EH is offline
post #2 of 7 (permalink) Old 12-26-2014, 07:49 PM
I like Fords Too's Avatar
compass is compleately self contained on the circut board the display is attached to - there's no other part to it unlike the temp with the sensor outside up front somewhere
check your owner's manual there may be a way to reset it - if not I'd expect it's pooched
I do seem to remember there being a way to set the compass in an older dodge - it's still the same stuff from some supplier so there should be a way
I like Fords Too is offline
post #3 of 7 (permalink) Old 12-27-2014, 02:41 AM
zip
zip's Avatar
My 03 F350 does have a way for doing the compass. First you have to set the zone then drive in circles till it is calibrated.
I don't know if yours is the same or not. I'm sure if you do a search you can find how to do it.
If that doesn't fix it there are places that repair them.
Chris
75 F150, 79 Bronco
zip is offline
post #4 of 7 (permalink) Old 12-28-2014, 10:31 PM
Your truck wants you to drive to Orillia.
I'd do it, and see what happens next.
post #5 of 7 (permalink) Old 12-29-2014, 09:03 AM Thread Starter
4X4 EH's Avatar
haha funny.
Yesterday the compass decided to indicate I was headed in a NE direction at one point, so now it is updating occasionally. WTF.
Orillia; been a few years since I've been there.
2003 Mach 1
2012 Shelby GT500
4X4 EH is offline
post #6 of 7 (permalink) Old 12-29-2014, 09:59 PM
I think zip had the right tip. I seem to recall having to calibrate my compass in a work truck some years ago (GMC). If I remember correctly, you had to put it in calibration mode through some magic sequence of button presses or something, and then drive it in a circle. So basically what he said. It was all in the owner's manual.
post #7 of 7 (permalink) Old 01-14-2015, 10:10 AM Thread Starter
4X4 EH's Avatar
My manual says to use the SET / RESET buttons to sync the compass. ONLY SET / RESET buttons my 2006 has are on the steering wheel used with cruise control. None the less I attempted to use these buttons as directed and got no where.
Anyone with a similar model ever have to 'reset' their compass and how did you accomplish??
2003 Mach 1
2012 Shelby GT500
4X4 EH is offline
Ford got stuck Alberta F150 Alberta 2 11-10-2014 04:24 PM
NEED HELP: stuck in 4 lo 4x4truckguy F-150 Pre-1997 Forum 5 09-16-2009 07:37 PM
COMPASS/TEMP GAUGE COMPUTER nf150 F-150 1997 to 2003 /04 Heritage Forum 4 09-04-2009 02:51 PM
