NEED HELP: air in coolant system (water sloshing) F150 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 01-14-2015, 03:33 PM Thread Starter
hi guys I got a problem that's got me doin summersalts.
ive got a 2002 supercrew ,322000 km
4.6L
2WD
heres my issue and what ive done
back in October intake gasket was replaced
everything fine till it got cooler in november
I could here air at the heatercore,(water sloshing around)
truck overheats ,pull over shut truck off,head safety sensor kicks in,
everything seems fine.start truck up everything is normal.this happened once a day and only when truck is cold, clear code replace thermostat.still happened
2 weeks ago I replaced rad because top hose was cold so I figured rad was plugged.i replaced reservoir cap
a couple days ago I started hearing water sloshing around again.that tells me air is getting into system.today it overheats ,I was in driveway waiting for truck to warm up.shut truck off wait 5 minutes restart everything ok.
I bled system of air ,drove around its fine again.
now it also takes about 20 Kms for me to feel heat.i fugure the heater core is plugged.
since ive replaced the rad I get less air.
I need to try and flush heater core and see if its plugged when it gets a bit warmer.
ive got no white smoke
don't have oil leaking into coolant
coolant level is not dropping
no coolant in oil
tailpipe is black so no coolant there
truck runs like a dream.
im baffeled
vic
swissgaurd is offline
post #2 of 7 (permalink) Old 01-14-2015, 06:04 PM
Sounds like maybe air pocket in heater core which can be a bitch at times to get rid of. I find usually have to get front end up in the air some in order to bleed it out
post #3 of 7 (permalink) Old 01-14-2015, 06:23 PM
Welcome to fordtough.ca, unfortunate your first post is having a problem with your ride, good luck finding a solution.
Lots of smart guys on here, hopefully you'll have some luck.
post #4 of 7 (permalink) Old 01-14-2015, 08:25 PM
Sounds like the thermostat is in backwards. Or the water pump may need replacement.
post #5 of 7 (permalink) Old 01-14-2015, 10:20 PM Thread Starter
i use a special funnel that goes on overflow.but air comes back slowly
post #6 of 7 (permalink) Old 01-14-2015, 10:23 PM Thread Starter
im starting to think the waterpump.can the impellar put air into system.
never had this issue with a waterpump.usually they just leak
post #7 of 7 (permalink) Old 01-15-2015, 06:19 PM
wolfman1's Avatar
You'll have a hard time purging the air out of the system if the waterpump isn't working
wolfman1 is offline
1998 f150/10th.gen cabin air filters GLENN F-150 1997 to 2003 /04 Heritage Forum 3 01-20-2014 09:05 AM
2002 F150 Transmission and Coolant flush Smith1994 F-150 1997 to 2003 /04 Heritage Forum 5 05-02-2013 10:40 PM
98 f150 ext cab 4x4 cold air intake problem..help duece F-150 1997 to 2003 /04 Heritage Forum 6 03-03-2008 10:24 PM
