f150 budget cat replacement options-southern Ontario - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 06-05-2015, 08:13 PM Thread Starter
So I bought a great looking older f150 and now looks like I'm in for a Cat replacement.
I'm getting the code p0430 bank 2 cat efficiency.
I'm seeing lots of guys talking about using magnaflow cats to replace but also seeing a lot of bad reviews of them on another f150 (USA) forum. Looking to see if i can save some $$ by ordering from the US but Does anyone know if 48 state legal will pass Ontario emissions? I'm planning on getting a universal and let a shop weld it in for me. Likely need to replace o2 sensor as well.
06 f150 screw xlt.
What would you guys recommend? Flowmaster/Wagner/Eastern/Bosal? And if I replace one will it sound "funny"?
Thanks Bones
Pre edit comment... the autocorrect on my phone has a mind of it's own.
Bagobones is offline
post #2 of 6 (permalink) Old 06-05-2015, 11:31 PM Thread Starter
Cat replacement options 06 f150 xlt
Need to replace a cat. looking at aftermarket options.
Hearing bad things about magnaflow quality. What other budget options are there? I don't need fancy, just need to pass the e test and get rid of the CEL.
I found direct fit Wagner Cats around $400.
Seen some universal Cats on US sites under $100 but i don't know if they would work well. Anyone tried cheap Cats? What works?
I'm in Ontario. Kitchener area.
post #3 of 6 (permalink) Old 06-06-2015, 07:04 AM
Get a 3 gas cat.
post #4 of 6 (permalink) Old 06-06-2015, 06:44 PM Thread Starter
I googled it but I'm not familiar with a 3 gas cat. Nothing comes up.
Do you have a link?
post #5 of 6 (permalink) Old 06-12-2015, 06:43 PM
Big Daddy D.'s Avatar
It is very important to have the shop identify why the catalytic converter failed. Failure is almost always due to another problem, which if not resolved, will quickly ruin a new catalytic converter.
A failing catalytic converter can cause a Ford F-150 to fail emissions tests and the Check Engine Light to illuminate. The exhaust might have an unusual smell.
A "restricted" catalytic converter can result in a loss of engine power.
Press on regardless!
Big Daddy D. is offline
post #6 of 6 (permalink) Old 06-15-2015, 01:29 PM Thread Starter
Good call Big Daddy. No driveability/performance issues as yet but going to take it in to get looked at next week. Hopefully find the cause.
Hi from Southern Alberta canadiantj New Members Introductions 10 11-10-2012 06:50 PM
diy budget drop 89 ford hihosilver Suspension 2 05-11-2012 07:00 PM
MEET/G2G: Southern Ontario Meet Waborita92 Ontario 4 05-25-2010 01:42 AM
I got one too, Southern Ont. ColinRX7 New Members Introductions 11 02-06-2008 11:11 AM
