2005 F150 5.4 3V Hard Start on first try. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 08-19-2015, 12:45 AM Thread Starter
I bought a used 2005 F150 with a 5.4 3V engine and since I had it it's hard to start usually just on the first try; if you try it on the second try it starts right up no issues. I have tried lots of things replacing the engine Oil/Coolant Temperature sensor (screws into the side of the oil pan), replaced Fuel Pump Drive Module, replaced the VCT solenoids in the engine, replaced the air filter, and replaced the fuel filter I even sprayed the MAF sensor with MAF sensor cleaner and sprayed the throttle body with throttle body cleaner. Another thing I tried is just priming the engine 5-6 times usually fixes the hard start, so I'm thinking it's either the check valve in the fuel pump assembly or the fuel rail pressure/temperature sensor? What do you guys all think might be the problem?
ajschwab2004 is offline
post #2 of 12 (permalink) Old 08-19-2015, 10:46 AM
Canadian Bacon's Avatar
Have you changed the spark plugs? Is it only in the morning or if you turn it off go into a store and come back out also?
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #3 of 12 (permalink) Old 08-19-2015, 03:59 PM Thread Starter
It does it all the time if I go into a store and its off for like 25 mins hard to start and if I try it in the morning for the first time hard to start. The only thing that works for me is if I prime it 5-6 times like if I'm building up fuel pressure to start that is the only thing that works.
post #4 of 12 (permalink) Old 08-23-2015, 10:20 AM
Big Daddy D.'s Avatar
I would be checking the fuel pressure, with your mechanic, as well as for codes.
Press on regardless!
Big Daddy D. is offline
post #5 of 12 (permalink) Old 08-23-2015, 12:26 PM Thread Starter
I work at Ford Dealer as a Lube Tech we hooked up to the computer and gave no codes. Even checked the fuel injectors to see if one was stuck open and the computer showed the injectors had no faults.
post #6 of 12 (permalink) Old 08-23-2015, 02:23 PM
I like Fords Too's Avatar
sounds like the fuel pessure is bleeding down when shut off
if nothing's leaking and the injectors are good I bet fuel pump is loseing it's inner sealing ableity being ten years old
I like Fords Too is offline
post #7 of 12 (permalink) Old 08-24-2015, 07:58 AM
Why does everyone rely on the computer to give them a code for things?
post #8 of 12 (permalink) Old 08-24-2015, 12:59 PM
because often it will give you the source problem or relay info related to an effect from the problem
good diagnostic procedure to check for codes
my old turbo fwd mopars were much better though as all you needed was to turn the key 3 times and the engine light would flash the codes for you
no computer / code reader needed
ford and gm always required a code reader which is gay - just brings more people into the shop because they can't read the codes themselves
granted it isn't always going to find an issue ... but if it does it's gonna save a butt load of time
post #9 of 12 (permalink) Old 04-19-2016, 08:16 AM
I agree... one must start somewhere...
post #10 of 12 (permalink) Old 09-13-2017, 04:09 AM
Well, i got my 4.6 and no issues. I would check the fuel pump, seems like the issue.
Dewast is offline
4.0L Ranger - Hard Start Blue Oval Ranger Forum 5 12-07-2014 02:07 PM
NEED HELP: 2005 Silver Metallic F150 XLT 4X4 5.4L 3.55 Ratio 145WB Scab deviance159 F-150 2004 to 2008 Forum 15 05-31-2013 07:19 PM
NEED HELP: Replace/Upgrade Foglight bulbs 2005 F150 Arn Lighting 4 10-28-2008 10:42 PM
2007 XLT 4.0L hard to start.....WTF?? Chienlaid Ranger Forum 12 07-30-2008 11:22 PM
