Airbag,code 27 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 05-16-2008, 10:06 PM Thread Starter
Talking Airbag,code 27
Hello folks :icon_smile:
I had an airbag code 27 last week. After some search on the subject on the net, I get on a site, were there was some ranger discussion. One of the guy had the same problem. The code 27 is the passenger deactivation switch and the light was burnt. Instead of changing the entire units, you simply need some time, a soldering iron and a lamp bulb from the source (code 272-1099). You just replace the burnt led by the bulb and for sure, it works fine.
total cost of the operation : $ 0.96 cents (it was on liquidation) and around 15 to 20 minutes.
Just wanna share this info
blueghost is offline
post #2 of 2 (permalink) Old 05-16-2008, 10:16 PM
Rockauto.com Discount Code f150phule Sticky Tech/How to Section 1 07-29-2008 03:43 PM
Engine code blueghost F-150 2004 to 2008 Forum 3 05-22-2008 12:42 PM
P-0307 Engine Code MRGADGET Gas Engines 14 01-17-2008 12:33 AM
AXLE CODE DECODER fordtough.ca Sticky Tech/How to Section 0 11-15-2007 06:38 PM
engine code?? silverfox Gas Engines 7 09-12-2007 10:05 PM
