Plowing with an f-150 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 07-13-2008, 12:45 PM Thread Starter
so,, who's got a plow on thier f-150,, i've started a landscaping buisness and been pulling my landscape trailer all summer with a 2004 fx4, and i dont know if another truck is in the budget yet, like a 250,, but,, what i have is what i got, wanted to know how its been with other people that have put a plow on thier trucks,, and what plows you might be using,
04fx4 is offline
post #2 of 4 (permalink) Old 07-13-2008, 01:30 PM
how much plowing do you plan to do ? you can get composite plows which are more expensive but less stress on your front end... (lighter)
im not sure if ford ever offered a plow option for the f150's something to look into beefier front end...
it will wear out your front end alot faster...
post #3 of 4 (permalink) Old 07-13-2008, 02:07 PM
i worked at delta spring and chassis installing plows, in an ideal situation having a 350 or 450 would be the best way to go, but like you said sometimes you gotta work with what you got, i've installed tons of plows on 150's, chev and dodge 1500s, i've even put em on rangers and jeeps, they all work great, it just limits you to the size of the blade you can put on and salt equipment you can carry if you choose, i'm not too sure about other brands but i've found with the boss brand plows we carried the poly blades were heavier than the steel blades, the advantage being the blades don't rust and the snow doesn't stick to them like the steel ones, the poly blades were more expensive than the steel
flip_86 is offline
post #4 of 4 (permalink) Old 07-22-2008, 08:10 PM
any way you slice it.......it's gonna be damn hard on your truck. F-250 or F-350 would be way more prefferred.......but go with a smaller plow (7 footer max) and try to take it easy.
pete74 is offline
What lifts for a 95 F-150? 86caprirs F-150 Pre-1997 Forum 5 04-02-2009 01:50 PM
Need to know more about your F-150 2004+ fordtough.ca Sticky Tech/How to Section 2 02-12-2008 12:45 AM
anyone lookin for a 150 2insane F-150 2004 to 2008 Forum 10 12-15-2007 12:56 PM
