Shimmy out of nowhere - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 08-08-2008, 06:22 AM Thread Starter
Wondering if anyone has suggestions of things to look for before I bring it to the dealer...
Out of nowhere on Tuesday my 07 screw starts shimming like I have a tire going flat. Happened during lunch hour, so parked it for a few hours, hop in to go home and it's fine from the get-go. Didn't drive her Thursday, this morning hop in and 1/2 way to work (after about 25kms) it starts up again worse than before. Shimmies at all speeds and damn near feels like the wheel is going to fall off. It feels like the right hand side of the truck... Tires look fine, nothing else that's obvious... .
Suggestions??
DoubleD is offline
post #2 of 13 (permalink) Old 08-08-2008, 10:31 AM
Smokeispower's Avatar
Check tire pressures? may be a slow leak.
Smokeispower is offline
post #3 of 13 (permalink) Old 08-08-2008, 10:44 AM
sounds tire related due to the fact the trouble starts after he's driven for awhile and the tire warms up. maybe a sidewall sepatation on the inside of the tire. if it was a bent rim or a out of balance rim due to mud build-up you would think that it would happen all the time.
post #4 of 13 (permalink) Old 08-09-2008, 01:18 AM
could be a warped rotor, my magnum does the same thing.
silver is offline
post #5 of 13 (permalink) Old 08-09-2008, 03:15 AM
Cooker's Avatar
Check Lug nut Torque. Does it get better/worse when your on the brakes?
Cooker is offline
post #6 of 13 (permalink) Old 08-09-2008, 08:26 AM
check your tires kinds sounds like a slipped belt if theres a bubble or out of shape side wall thats probly your problem.... sometimes they just fail but they do also if you hit a curb or hard object with the tire
if its a rotor it should shake when you break and if its on the front it should shake the steering wheel in your hand
or if you have enemies or pranksters (bad ones) check your lugnuts if there loose chances are it will shake and has probly oblonged the holes so it dinked the rim.... some idea's
post #7 of 13 (permalink) Old 08-10-2008, 07:52 AM
4X4 EH's Avatar
My 1st thought.
2003 Mach 1
2012 Shelby GT500
4X4 EH is offline
post #8 of 13 (permalink) Old 08-10-2008, 09:02 AM
I got the same thing in my 07 screw, with 20's and we took it to the dealer, checked the tire pressure, lug nuts, rotors, had them look at the nuts and bolts, nothing was wrong, more than likely the big tire following all the ruts in the road, it goes away on a smoother surface or on new pavement, so that's more than likely what it is????, I hope...
Not to mention that the GF has huge boobs, so it's all good to watch anyway..:icon_ee k:
04STXHERITAGE is offline
post #9 of 13 (permalink) Old 08-10-2008, 02:11 PM
4X4 EH's Avatar
2003 Mach 1
2012 Shelby GT500
4X4 EH is offline
post #10 of 13 (permalink) Old 08-10-2008, 03:30 PM
yeh,yeh. pics,pics
