Cold air intake... off road - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 28 (permalink) Old 09-07-2008, 01:20 PM Thread Starter
So I ordered a catalog from www.lmctruck.com, and was looking through the intakes, they have a few to select from but one was labeled to be illegal for streets and off road only, just wondering if anybody knows why it might be that way? It looked similar to the rest of them, although it didn't look to have the MAF sensor in it. But I don't think taking that out and putting a simulator would be useful would it?
It still may be in there I just failed to see one, I was thinking of ordering this one(for when I go off road ) to see if it makes any improvement. It just made no sense as to why it could be illegal.
kits_hacker is offline
post #2 of 28 (permalink) Old 09-07-2008, 01:35 PM
That means that it wasn't approve and or tested by CARB (California governmental agency that promotes and protects public health)
Most aftermarket intakes come with carb e.o. numbers. I'm pretty sure depending on what brand has that info stemped right on it.
Your engine may run too lean or rich with that intake and it may throw codes to your computer
post #3 of 28 (permalink) Old 09-07-2008, 02:30 PM
I got a cold air intake from a dodge neon! haha and it makes he run better too! lol
post #4 of 28 (permalink) Old 09-07-2008, 02:34 PM Thread Starter
usually you just unplug the battery if the check engine light comes on from intakes, that's an easy fix I was just curious why its off road only. thanks
I was acctually looking at my intake one day and other then the 2" hole going into the frame, there's not much else to deflect the air flow inside it (02 f-150 5.4) there's a small hole in the elbow but that's a simple plug it with something to stop air from gettin trapped in there, otherwise I'm thinking I might just grab a K&N filter and cut open my airbox like everyone else does, much cheaper then spending the 150+ dollars
post #5 of 28 (permalink) Old 09-07-2008, 02:36 PM
post #6 of 28 (permalink) Old 09-07-2008, 07:12 PM
very few of them meet CARB.........no biggie.
Airaid is prolly the best followed by K&N........atleast the most power can be achieved through custom tuning with one of these 2 (usually airaid).
pete74 is offline
post #7 of 28 (permalink) Old 09-07-2008, 09:00 PM Thread Starter
yah i'm still in debate about it, i don't believe i would feel much difference with buying one, but on the other hand i do like the looks of the chrome under the hood and it looks less tacky then cutting my air box apart
post #8 of 28 (permalink) Old 09-09-2008, 09:50 AM
Volant makes a true CAI by utilizing the fender opening. The Airaid is a nice unit (had one) but it ends up sucking the hot air generated by the engine even with a heat shield.
primerib is offline
post #9 of 28 (permalink) Old 09-09-2008, 10:37 AM
Airaid is still considered by many of the major tuners to be the one that can produce the most additional horsepower.
And technically speaking the Airaid and K&N are not considered CAI's. They are FIPK's........Filtered Intake Performance Kits.
pete74 is offline
post #10 of 28 (permalink) Old 09-09-2008, 06:38 PM
I can't see an intake making any difference even with custom tuning unless you are running a blower. My tuner guy is one of the best in my area...knows Mike Troyer quite well and he told me there is little or no gains running aftermarket intakes even with my Volant and Airaid kits. Our intakes are meant to produce goobs amount of air at low rpms but that is the problem as well since they don't breath well from mid range on. I can see a Mustang intake can work much better with an CAI but not our trucks.
Sorry but I'm running a ton of bolt on mods and to be honest only headers and an Xcal-3custom tunes yield positive results.
primerib is offline
NEED HELP: Cold Air intakes black on black fx2 F-150 2004 to 2008 Forum 16 07-25-2009 07:20 PM
2007 4.6 cold air intake sid60 F-150 2004 to 2008 Forum 1 09-19-2008 02:15 PM
98 f150 ext cab 4x4 cold air intake problem..help duece F-150 1997 to 2003 /04 Heritage Forum 6 03-03-2008 10:24 PM
Cold Air Intake? Coruptyed Intake, Exhaust 22 03-01-2008 04:26 PM
Cold Weather Starting Ottawaguy F-150 Pre-1997 Forum 9 02-21-2008 10:50 PM
