leveling kit - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 03-27-2009, 04:58 PM Thread Starter
lonerangerxlt's Avatar
Location: creston bc/all bc (depending on the town i am in for work)
leveling kit
i have a 2005 F-150 xlt and i put the leveling kit in the truck a wile ago and i just took my truck into ford for them to take a look at the problems i am having with it and they told me because of my leveling kit the hole front end has to be replaced just because of the 2.5'' blocks
anyone elso have this problem with there ford
lonerangerxlt is offline
post #2 of 6 (permalink) Old 03-27-2009, 05:25 PM
Bates88's Avatar
Get a second opinion! Dealerships love to lay blame at aftermarket parts whether it's the problem or not. On the other hand lifts can increase the wear & tear on your truck or amplify any existing problems.
Banks Powered FX2
Bates88 is offline
post #3 of 6 (permalink) Old 03-27-2009, 07:04 PM
tohi2care's Avatar
I have over 60,000kms on my 2.5 inch spacers an I wheel with my truck occasionally and I have had absolutley no problems. Ask them for a written document asking for a detailed description of how the spacers caused the problems to your front end.
tohi2care is offline
post #4 of 6 (permalink) Old 03-27-2009, 08:19 PM Thread Starter
well i know for a fact that the drivers side hub assembley (bearings) are almost gone
i know this because i have changed like 4 or 5 of them on my ranger
but they told me that they were causing the front end to bind up
post #5 of 6 (permalink) Old 03-27-2009, 08:49 PM
tohi2care's Avatar
As I said get a better explanation because "causing the front end to bind up" is a pretty vague description of the damage and how it was caused.
post #6 of 6 (permalink) Old 03-28-2009, 12:50 AM
in most cases it's not the leveling kit that causes the exellerated wear on front end components but the tire size and the way the truck is drivin,that being said ask them to give you the actual readings on the worn parts and the manuel specs(.032" lower ball joint deflection/.008 on the uppers)even new parts will have some deflection as they use a ball and socket fitting.
Leveling kit? E36er Suspension 79 06-05-2009 07:37 PM
F350 leveling kit install firefighter38 Photo and Video Gallery - Members Rides 9 02-03-2009 03:54 PM
EVERYTHING YOU WANT TO KNOW ABOUT LEVELING KITS tohi2care F-150 2004 to 2008 Forum 0 01-25-2009 03:45 PM
Icon or Bilstein leveling kit duckdog F-150 2009 to 2014 Forum 6 11-15-2008 02:09 PM
Leveling kit and tires installed! ScottyV Truck/SUV Talk 22 11-14-2008 03:34 PM
