flickering digital odometer /temp guage - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 05-11-2010, 08:08 AM Thread Starter
My odometer/temp guage is flickering and sometimes going out for a day. It seems to have something to do with heat because its worst on hot days?
Any advise/fixes?
xdallairex is offline
post #2 of 4 (permalink) Old 05-13-2010, 01:21 AM
you could remove the cluster and check the wiring connector,but the message center is non servicable and comes with the cluster.
post #3 of 4 (permalink) Old 05-15-2010, 08:49 PM
I had the same issue on 05. It was still under warranty at the time, they said it was the bulb at first and then ended up replacing the whole cluster. I don't know if it's an issue with a loose connection or just a faulty cluster, but I haven't had an issue with the new one.
Good luck
BCwheeler is offline
post #4 of 4 (permalink) Old 05-15-2010, 09:02 PM
maplesyrup's Avatar
I had an issue with this on a dodge i used to own...the rear got so hot that it melted the solder and fused it together causing a short and same things were happening...might be it..if its warrantied take it in, if not take out your cluster and check the back
maplesyrup is offline
'03 4.6 temp. sensor repair Triton F-150 1997 to 2003 /04 Heritage Forum 5 01-04-2010 12:45 AM
NEED HELP: Fuel guage fluctuates sometimes.... Arctic F-150 F-150 2004 to 2008 Forum 11 07-09-2009 12:20 AM
Digital Display probleme BCwheeler F-150 2004 to 2008 Forum 7 11-28-2008 12:12 AM
Tranny Temp sensor Roadwarrior Driveline and Transmission 10 08-17-2008 03:41 PM
