Lower Frt Strut Bolt - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 06-06-2010, 07:10 PM Thread Starter
Quick question, does anyone know what socket size for the lower strut bolt on an 08 F150. Im doing my level kit and rough country gave wronge socket size in the instructions.
Thanks Tons
bboybean is offline
post #2 of 10 (permalink) Old 06-06-2010, 08:25 PM
murray99's Avatar
I think its 30mm deep socket. I put my kit in with out pulling the shock, but much easier
with shock out.
murray99 is offline
post #3 of 10 (permalink) Old 06-06-2010, 08:26 PM
As per Hellbentsteels's instructions
Step 7 7. Next remove the struts lower bolt. Using a 27 mm wrench, hold
the nut and remove the bolt with a 30 mm socket.
good luck and post some pics of before and after.
EDIT...Murray beat me to it..lol
post #4 of 10 (permalink) Old 06-06-2010, 11:03 PM Thread Starter
Thanks tons everyone, Ill post pics after im done. The instructions I got said 29mm socket
bboybean is offline
post #5 of 10 (permalink) Old 06-30-2010, 01:52 AM Thread Starter
Well tried it again and no dice. I can't get the balljoint out no matter what. Is anyone in the North Edmonton St.Albert AB area willing to spare an hour and help me. I can't afford to take it to a shop but I have beer and pizza . I tried a ball joint separator and heat and soaking it in wd40. Grrrrrrrrr
bboybean is offline
post #6 of 10 (permalink) Old 06-30-2010, 03:21 PM
you shouldn't have to separate lower ball joint,just make sure not to lift under control arm,undo strut top 3 nuts and lower bolt and remove strut assm.
post #7 of 10 (permalink) Old 07-07-2010, 07:09 PM Thread Starter
Im still trying to get the upper balljoint seperated. The 30mm socket doesnt fit (grrr). I dont know whats wronge but im completly stumped. I swear im not retarded when it comes to this but nothings working.
bboybean is offline
post #8 of 10 (permalink) Old 07-08-2010, 03:10 PM
put jack under the control arm, jack it up till you see the spindle move up so the upper control arm is at natural possession, the upper a arm nut is a 19or21mm socket. take that nut off. wack with a ball peen hammer the spindle where the upper ball joint goes in the spindle 2-5x, lower jack a lil the upper ball join should come out.
post #9 of 10 (permalink) Old 07-08-2010, 03:11 PM
http://www.youtube.com/watch?v=QgpkDdReAqA
post #10 of 10 (permalink) Old 07-08-2010, 03:13 PM
watch the vid clip ^^^^^^^
converts 5x5.5 to the F350 bolt pattern???? Ford00XLT F-150 1997 to 2003 /04 Heritage Forum 2 04-22-2009 11:01 PM
Thread/bolt size blueranger Ranger Forum 11 07-30-2008 12:10 PM
bolt pattern? mechanix61 Super Duty Forum 4 05-02-2008 07:45 PM
Theft Resistant Hitch Bolt truckpilot Exterior 1 11-30-2007 10:36 AM
