NEED HELP: Tightening Tubular Running Board Step - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 07-10-2010, 05:27 PM Thread Starter
I recently bought an '04 SuperCrew. The chrome tubular running boards have a plastic step fastened to the tube under each door with torx screws.
I have one that's loose and it won't tighten. It makes it a bit risky at times getting in and out because it shifts a bit when you step on it.
Any ideas how to get these screws tightened? I can tighten and loosen all day without getting them to make any difference. I even tried getting some extended needle nose pliers in there to try to grab onto the clip (I assume there's a clip in there) with no luck.
Any help would be appreciated.
thanks!
SCrew Lariat is offline
post #2 of 6 (permalink) Old 07-10-2010, 10:01 PM
what about taking the screw out drill a bit bigger hole and put in a bigger screw ?
post #3 of 6 (permalink) Old 07-11-2010, 03:21 AM Thread Starter
I thought about doing that but I suspect they aren't screwed directly to the running board but rather to some type of clip which has come loose.
if only I could see in there.....
post #4 of 6 (permalink) Old 07-11-2010, 11:46 AM Thread Starter
also, the screws don't seem to want to come out.... they just keep turning without tightening or loosening
post #5 of 6 (permalink) Old 07-11-2010, 12:05 PM
How about if you can lift the plastic peice enough to put some 3m double sided tape in there to hold it down, then just glue the screw down to keep it from poppin up.
post #6 of 6 (permalink) Old 07-31-2010, 11:36 AM Thread Starter
Thanks for the suggestions.
If anyone has ever managed to get the plastic steps off, please let me know how it's done.
It's funny how something so simple can be so complicated.
Anyone using Dee Zee Rough Step Running Boards? ric_no_k F-150 2009 to 2014 Forum 6 07-09-2010 05:58 PM
Glad to be 'on board' glassman08 New Members Introductions 15 01-18-2010 03:55 PM
2" FRAME LIFT step by step pics Henry Ford F-150 Pre-1997 Forum 2 05-20-2009 11:18 PM
Any Ford partsmen on the board ? flattop414 Gas Engines 1 09-18-2008 01:40 AM
