04 f150 turn signal problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 10-12-2010, 04:59 AM Thread Starter
So I have been havin a strange issue with the turn signals lately. They work some days, and others it'll blink a couple times and stop. and now they just don't work at all. When I innitially switch the signal it very briefly flashes just once and stays off after that.
All other lights are working fine, and even the hazard lights are fine.
I was told the flasher for the turn signals is the same for the hazard lights. If that's the case it likely isn't the flasher. And since the lights come on for the hazard lighting it likely isn't bulbs.
I seem to think I notice the problem more frequently during rain as well, but maybe I'm being paranoid.
Loose wire in the signal shifter maybe? Unless moisture could get into somewhere that might effect only the turn signals.
Anyone else had this problem?
Mayhem is offline
post #2 of 4 (permalink) Old 10-12-2010, 04:02 PM
try testing the m/f switch,test for cont beween pin1/8,1/7 for lh,pin 1/5,1/6 for rh should be closed(low resistance)when in position.
post #3 of 4 (permalink) Old 10-13-2010, 08:43 AM
Blue Oval's Avatar
If memory serves the multi-function switch is a one piece plug and play type assembly. Chances are if you're having an issue with your signals it's the switch that's faulty, especially given that your four-ways still work fine.
If you find shelby's test shows a faulty switch it's a pretty simple repair.
Blue Oval is offline
post #4 of 4 (permalink) Old 10-19-2010, 05:19 PM Thread Starter
Nearly forgot to come back on and thank yall.
It did turn out to be the m/f switch
all better now.
Mayhem is offline
NEED HELP: 2004 F150 Heater Problem BigDawg99 Interior 11 12-19-2009 08:38 AM
NEED HELP: 2007 F150 will not turn over Fordxlr8r F-150 2004 to 2008 Forum 4 06-23-2009 01:15 AM
signal bulbs shelbyx1 Truck/SUV Talk 18 01-20-2009 01:38 PM
98 f150 ext cab 4x4 cold air intake problem..help duece F-150 1997 to 2003 /04 Heritage Forum 6 03-03-2008 11:24 PM
Left Turn Signal on When breaking PMarch Ranger Forum 23 12-28-2007 04:40 PM
