F150 - OBD CODE 1288 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 10-18-2010, 07:04 PM Thread Starter
2008 Ford 150 FX4; 5.4; 93,000 km
After pulling my boat trailer, my truck started running extremely rough, almost like it went into limp mode. It was only a 20 minute trip pulling the boat. I reved it up a couple of times and then it seemed to run normally. So far, it is running normally. I had a very similar occurance early in the year pulling my travel trailer when it was +32 and going into a head wind. In both cases, neither the Service Engine light or any lights came on. Ran diagnostics this time it and comes up with P1288 -1. Cylinder Head Temperature Sensor out of Range: 2. Cylinder Head Temperature Sensor out of Range Can anyone tell me exactly what this means? I talked to one mechanic and he says this is a common problem in Fords and he attributed it to a plugged catalytic converter.
The motor was not overheating nor was it labouring as the boat and trailer only weigh 2,000 pounds. I had the plugs replaced about three weeks ago.
garymac221 is offline
post #2 of 4 (permalink) Old 10-19-2010, 03:33 PM
check to see if your rad or condensor are plugged cutting off airflow.
post #3 of 4 (permalink) Old 10-19-2010, 07:01 PM Thread Starter
Believe it or not, I had to replace the rad in June of this year, so it is clean as is the a/c condenser rad
post #4 of 4 (permalink) Old 10-20-2010, 03:58 PM
you could check the cht sensor resistance to see if you have a bias sensor.
Code Help Ill Named F-150 2004 to 2008 Forum 5 05-04-2009 09:53 PM
NEED HELP: Code Reader anyone? Coruptyed Programmers and Tunes 17 12-03-2008 03:56 PM
Engine code blueghost F-150 2004 to 2008 Forum 3 05-22-2008 01:42 PM
Airbag,code 27 blueghost F-150 2004 to 2008 Forum 1 05-16-2008 11:16 PM
engine code?? silverfox Gas Engines 7 09-12-2007 11:05 PM
