Do our trucks take longer to warm up? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 12-08-2010, 08:51 AM Thread Starter
Just replaced the thermostat in my '05 because I thought it was stuck open.When I would start it up in the cold winter weather, & let it idle for even 10 minutes, I would hop in and the temp guage barely moved. I would take my 7 mile commute thru the city to work and only a couple miles before I get there does needle finally reach normal operating temp & heater blow hot air.
After replacing thermostat, I noticed barely any change, so before I pull the thermostat again I am just wondering if these trucks take longer than the average vehicle to warm up? Or could it be something else? (I had the block heater plugged in & have a winter front on the truck.)
I have owned quite a few different trucks/cars in the past and so far this truck seems to take far longer to warm up than anything I have owned. Anyone else?
rvx290 is offline
post #2 of 10 (permalink) Old 12-08-2010, 10:17 AM
maplesyrup's Avatar
Wow, no mine warms up quick! 10 minutes and it would be toasty inside at -30. Is you fan stuck on?
maplesyrup is offline
post #3 of 10 (permalink) Old 12-08-2010, 12:24 PM
Mine warms up quick too. With the block heater plugged in at -30 and about 5 minutes of warm up time it blow hot air and the temp gauge is at 1/4. I'm wondering the same thing as maplesyrup, maybe your fan is kicking in when it shouldn't be.
post #4 of 10 (permalink) Old 12-08-2010, 06:06 PM
swackly's Avatar
My truck is warm after 5 min drive
swackly is offline
post #5 of 10 (permalink) Old 12-08-2010, 06:26 PM
you could have an airlock in the system try filling coolant cold with heater hose unhooked until coolant comes out reattach hose and finish filling overflow.
post #6 of 10 (permalink) Old 12-08-2010, 08:59 PM
I don't use my block heater but then again it's only -5 here, 10 minutes after start up and truck is toasty inside and heat gauge is at normal and I have a supercrew with the 4.6
post #7 of 10 (permalink) Old 12-10-2010, 01:51 AM
10 min to a toasty warm truck for me as well
post #8 of 10 (permalink) Old 12-10-2010, 11:48 PM
5mins of driving truck is up to temp. .. maybe 10 max and i'll be turning it down.
post #9 of 10 (permalink) Old 12-11-2010, 08:22 PM
Blue Oval's Avatar
I'm thinking airlock...
You could also test the thermostat - could be a defective unit even though it's new.
Boil some water in a pot on the stove and see if it opens up.
Blue Oval is offline
post #10 of 10 (permalink) Old 12-11-2010, 08:54 PM
I was gonna just say what you said Blue Oval ( lol )
I have had bad thermostats from different stores new only way to check them is with boiling water.
new to trucks JosiahP New Members Introductions 11 06-21-2010 03:45 PM
My New Trucks zip F-150 Pre-1997 Forum 11 10-16-2009 03:47 AM
Longer antenna? Slim Ranger Forum 15 05-20-2009 10:48 AM
Superduty warm up questions Arkas Super Duty Forum 1 03-16-2009 09:30 AM
WARM mitchykins Alberta 16 03-10-2009 07:58 PM
