body lift? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-14-2010, 04:33 AM Thread Starter
Rob07's Avatar
body lift?
I installed a 4" Rancho suspension lift on my 07 lariat a while back and now im curious about adding a body lift maybe 3". If anybody has it done or knows why it shouldnt be done i would greatly appreciate the advise thanks
Rob07 is offline
post #2 of 7 (permalink) Old 12-14-2010, 09:10 AM
lol
Would love to see that suspension lift - post up a pic when you get a chance. I would think after doing the suspension lift, the body lift would be a piece of cake.
post #3 of 7 (permalink) Old 12-14-2010, 09:45 AM
3" body lifts are an ok install did one on my exploder believe it or not the PITA part is makeing sure the body is straight on the frame after. That you have all the brake line extenders ahead of time even if they say you wont need them look at them ahead of time most times they could need to be extended and when not are left tight.
also your exhaust will need to be adjusted higher after the lift
post #4 of 7 (permalink) Old 12-14-2010, 10:23 AM
Did one on my old 90 F250..it was ok, except for the tranny/transfer case boots..had to cut them a little to fit. Also you might want to see if your tranny linkage needs an extension welded to it to make up the difference. My 90 was a stick, so wasn't an issue for me..Another issue i ran into was the fan hitting the rad shroud while flexing. Had to trim the shroud a little..There are a few guys here running them, so hopefully one of them will chime in with advice.
post #5 of 7 (permalink) Old 12-14-2010, 10:56 AM
Ken24's Avatar
I've got a 3 inch Body Lift on my 98 Expedition, and I like it. Have had no issues other than making my truck awesome!!!!!
Ken24 is offline
post #6 of 7 (permalink) Old 12-14-2010, 03:30 PM
i did it on my 04 took a good day and a half. i got the p/a kit came with everything.
post #7 of 7 (permalink) Old 12-14-2010, 11:51 PM
I put one on my old 02 and it was awsome, got the PA kit as well. Gap guards are a must as I drowned 2 alternators in mine without them.
leveling kit plus body lift 07STX Suspension 1 08-19-2010 10:44 PM
Body lift is done. Looks awesome!!!! Ken24 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 10 01-06-2010 10:33 AM
Whoo Hoo. Body Lift is here!!! Ken24 Excursion, Expedition, Navigator, Bronco, Explorer, Escape, Flex, Edge 11 12-31-2009 11:32 PM
Body lift install? Hanon Ranger Forum 17 02-20-2009 05:25 PM
Body lift is installed Bush_aholic Off Road 43 12-23-2008 06:02 PM
