Power steering problem? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 14 (permalink) Old 02-11-2011, 08:34 PM Thread Starter
Over the last week or so, I have noticed that my truck is hard to steer. The steering wheel doesn't center itself going around a corner anymore. It almost feels like driving with 2 flat tires. I do not believe that my front hubs are locked in, haven't checked yet though. Power steering fluid is just above the min line when cold and just below the max line when hot. I've done some searching and found possible problems from the rack and pinion to a high pressure valve. I'm really at a loss here and am a little concerned about doing some expensive damage. I should add that the problem is worse when it is cold and seems to get little better as the truck warms up. ANY ideas are much appreciated
edit: the issue is intermittent
post #2 of 14 (permalink) Old 02-12-2011, 03:01 AM
I don't know for sure, but the fact that it changes with temperature seems consistent with a problem in the hydraulic circuit. As hydraulic fluid increases in temperature, it becomes slightly less viscous.
Your truck is pretty new though, isn't it? Should be covered under warranty, if so.
post #3 of 14 (permalink) Old 02-12-2011, 03:24 PM Thread Starter
Nope no warranty. Its an 06, they only came with a 3 year 60k km warranty
post #4 of 14 (permalink) Old 02-12-2011, 08:39 PM Thread Starter
Well I know its not my hubs. With the truck running in 2wd I can turn both CV's by hand. Flip it into 4 HI and I can't turn either one, so I know they are working properly
post #5 of 14 (permalink) Old 02-12-2011, 08:50 PM Thread Starter
Edited the first post.
Since this issue is intermittent do you guys think it could be possible that the IWE solenoid is acting up? It is the older style, without the shield
post #6 of 14 (permalink) Old 03-18-2011, 03:13 PM Thread Starter
UPDATE
I finally got around to getting this issue fixed. The problem was the u-joints on the steering shaft. The lower one was seized solid. $320 later my truck drives like new. The mechanic that diagnosed and fixed it told me that they are replacing these on a lot of F150's. So anyone with oddly stiff steering, check the u-joints on the steering shaft!
post #7 of 14 (permalink) Old 03-19-2011, 02:41 PM
1BAD4D's Avatar
hey 07 rangersport, too bad i read this too late, i probably could have saved you $320 i had the same problem. what i did is I just sprayed so lube on the the u joints. with in seconds of turning the steering left to right. it lossened up. its goin on two years now with out a problem.
1BAD4D is offline
post #8 of 14 (permalink) Old 03-19-2011, 03:01 PM Thread Starter
I tried that before I agreed to do the repair. It worked for 3 days
They were in pretty bad shape
post #9 of 14 (permalink) Old 03-19-2011, 03:07 PM
1BAD4D's Avatar
aslong as its working thats all that matters.
1BAD4D is offline
post #10 of 14 (permalink) Old 03-19-2011, 03:13 PM Thread Starter
Yes it is
I'm glad it's back to normal
NEED HELP: Noisy Power Steering Pump Destructicon F-150 Pre-1997 Forum 10 05-24-2010 12:21 PM
bubbling power steering fluid?? 07harley F-150 2004 to 2008 Forum 4 05-23-2010 09:05 AM
Power Window Problem TowRig Audio and Electronics 2 10-09-2009 08:47 PM
tight power steering 1-800-bigtruck Sticky Tech/How to Section 6 03-07-2009 04:58 PM
Power Steering fluid/ price of motor oil truckguy94 F-150 Pre-1997 Forum 0 12-18-2008 12:16 PM
