Battery - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 03-02-2011, 08:58 PM Thread Starter
maplesyrup's Avatar
Battery
Well my battery has been giving me issues at cold days, -38 in the morning and it didn't want to turn over. Just wondering what you guys have had for good experience with batteries in our extreme colds. When i get back from GP i have to buy one.
Thanks.
maplesyrup is offline
post #2 of 13 (permalink) Old 03-02-2011, 09:04 PM
Optima Yellow Top
post #3 of 13 (permalink) Old 03-02-2011, 10:16 PM
Even a really good battery is going to start having problems at those low temperatures.
Batteries depend on a chemical reaction to produce electric current. Chemical reactions slow down the more the temperature drops. You need to raise the temperature of the reaction.
I use an electric battery blanket along with my block heater. A battery warmer is easy to install and only around $30, or so.
The real advantage to this is that once I start the truck and unplug the block heater/battery warmer, the battery remains warm while the alternator is charging it. A cold battery won't accept a charge as well as a warm one. This also increases the life of the battery.
post #4 of 13 (permalink) Old 03-03-2011, 09:36 PM Thread Starter
maplesyrup's Avatar
Yeah makes sense, but I do need a new battery regardless so might as well buy a good one instead of cheaping out. Thanks for input guys.
post #5 of 13 (permalink) Old 03-03-2011, 10:41 PM
Just my experience, but over the years I've had all sorts of different batteries, from top of the line expensive Sears Die-Hard, to the el-cheapo ones they keep under the counter at Canadian Tire for $40.
The expensive batteries have consistently crapped-out on me sooner than the cheap ones.
Oddly enough, I've had the best luck with the el-cheapos. Just keep 'em clean and make sure they're topped up with distilled, de-ionized water (not tap water). YMMV.
post #6 of 13 (permalink) Old 03-03-2011, 11:48 PM
I have always used Motocraft batteries from Ford. They last a long time and have never left me stranded. After 25 years of owning Ford trucks I probably buy a new battery every 5 yrs. I just replace my old one at the first sign it gets weak which is usually the first cold day in the fall. The stock battery in my 1987 Ranger lasted 7 years and I replaced because it was 7 years old not because it didn't work.
2007 F-150
2009 CRF450R
buffalo1973 is offline
post #7 of 13 (permalink) Old 03-04-2011, 12:44 AM
4-5 years is the life span of a battery that lives in canada worm/cold weather..... i wish we all lived in Arizona... no rust and batteries lived forever...lol
post #8 of 13 (permalink) Old 03-05-2011, 09:47 AM Thread Starter
maplesyrup's Avatar
hahah ya if only we had that climate, I like living up here :D
post #9 of 13 (permalink) Old 03-05-2011, 02:22 PM
IF you don't mind spending a little more get an Odyssey IMO these battery's do better then the optima but they are more pricey .,,
http://www.odysseybattery.com/batteries.html
post #10 of 13 (permalink) Old 03-05-2011, 11:29 PM Thread Starter
maplesyrup's Avatar
Appreciated! And no i dont mind dishing out for good stuff, thanks will look into it for sure!
NEED HELP: Battery light seanm Ranger Forum 9 01-01-2011 04:09 PM
second battery greger F-150 2004 to 2008 Forum 2 03-27-2010 10:50 PM
Battery Died haywire F-150 2004 to 2008 Forum 3 02-14-2010 02:19 PM
Battery Dies! Cowboy Ranger Forum 11 01-31-2010 02:08 PM
NEED HELP: BATTERY MJG Truck/SUV Talk 10 01-19-2010 07:14 PM
