NEED HELP: 2008 SD P0088 code - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 05-03-2011, 03:22 PM Thread Starter
2008 SD P0088 code
Can any one help me the this code. I have been told the repair cost could be quite costly any in put.
speed711 is offline
post #2 of 7 (permalink) Old 05-03-2011, 05:30 PM
Sounds like the High Pressure Fuel Pump might be heading south. I believe it's a Cab off repair, ouch. I assume warranty is gone? If not, hopefully you have receipts for fuel filter changes in case they are looking for an escape route.
post #3 of 7 (permalink) Old 05-03-2011, 10:35 PM Thread Starter
do you have any idea of the $ amount.
speed711 is offline
post #4 of 7 (permalink) Old 05-04-2011, 12:53 PM
Sorry, I don't know and it's just a hunch. Someone else may chime in that knows better.
post #5 of 7 (permalink) Old 12-10-2012, 08:42 AM
mitchell calls for 11 hours with cab on and 14 with cab off plus whatever the cost of the pump is
powerchoke is offline
post #6 of 7 (permalink) Old 02-11-2014, 01:52 AM
It's a 4500 dollar repare
mech55 is offline
post #7 of 7 (permalink) Old 02-21-2014, 02:23 AM
old thread, but be advised that there is a reflash for the PCM in 6.4 trucks. P0088 was a common issue and many high pressure pumps (and associated wiring) were changed for it.
make sure the reflash is done before doing the pump re and re. going that route might save a lot of money.
Varsity Tyler is offline
NEED HELP: Help Please P061B code simonw F-150 2004 to 2008 Forum 11 05-03-2014 07:12 AM
Code Help Ill Named F-150 2004 to 2008 Forum 5 05-04-2009 09:53 PM
Engine code blueghost F-150 2004 to 2008 Forum 3 05-22-2008 01:42 PM
Airbag,code 27 blueghost F-150 2004 to 2008 Forum 1 05-16-2008 11:16 PM
engine code?? silverfox Gas Engines 7 09-12-2007 11:05 PM
