Smoking coming from the front wheel... - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 06-05-2011, 01:55 PM Thread Starter
Hi guys,
today i went shopping and arriving home, i saw a bunch of smoke coming from the front left wheel.. i had to put water, cause i had no idea what could have been and it stopped after a while... i have no idea why... i didn't see any oil coming out, the breaks look ok to me... i noticed one thing though is has you can see in the pictures that there is 2 rings (one on each wheel) that seem to float around and i really dont think it's normal..
could that be the smoking coming from? The truck is a 2009 F250 with only 20000 km on it..
can some of you knows what that ring is ?
William!
will99 is offline
post #2 of 13 (permalink) Old 06-05-2011, 03:01 PM Thread Starter
UPDATE:
i saw that the caliper where the smoke was coming up was not the same color... i think the breaks got stuck and that's what happen...
but now, how do we UNSTUCK the breaks?
Anybody knows?
thanks
William!
will99 is offline
post #3 of 13 (permalink) Old 06-05-2011, 03:06 PM
That seal always breaks down...it's common. It's supposed to prevent crap from entering the axle tube.
As far as the brakes, you will have to remove the caliper and inspect. Sounds like seized slide pins.
LOOSEWHEEL is offline
post #4 of 13 (permalink) Old 06-05-2011, 04:08 PM
I would check the manual.
if there is nothing in the maintance book about brake work.
or if you've keep your maintance up to date.
should be covered under warranty.
post #5 of 13 (permalink) Old 06-05-2011, 06:31 PM
As for the picture you posted the ring is a seal to keep dirty and crap out of the axel and bearings, which you should get fixed. as for your caliper I'd take it back to the dealer as your truck is under warranty .
post #6 of 13 (permalink) Old 06-05-2011, 08:25 PM Thread Starter
The truck is getting towed first thing in the morning... plus there is a recall on it so i will do everything at the same time
But why is it doing that?
thanks
William!
will99 is offline
post #7 of 13 (permalink) Old 06-05-2011, 10:41 PM
thanks
William!
Do you drive it much? Does it sit alot?
post #8 of 13 (permalink) Old 06-06-2011, 11:06 AM Thread Starter
I dont even do 10Km per year... the truck now has only 20K. I mostly use it in the weekends only.. hehe
Why?
William!
will99 is offline
post #9 of 13 (permalink) Old 06-06-2011, 01:11 PM
might have just seized up from not being used.
it looks pretty rusty in that pic.. possibly from sitting on gravel and having so much moisture sitting on the truck it's corroded up?
post #10 of 13 (permalink) Old 06-06-2011, 08:15 PM Thread Starter
The truck is not even 2 years old, i had it sprayed with anti-rust last year and as you say it's still rust... If it continues like that in 3 years i will have to buy a new truck cause this one will be in ruin by the rust? Gees thank god they are made strong? And what's the difference between a truck that moves and one that doesn't???
thanks
William!
will99 is offline
Coming Home HTRDDSL Alberta 21 04-07-2011 08:00 PM
Creaking sound from front drivers side wheel area. Ken24 Suspension 8 02-12-2010 07:16 PM
Cruise not coming on nf150 F-150 1997 to 2003 /04 Heritage Forum 12 08-19-2009 04:02 PM
