EGR delete- Engine Light - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 05-25-2012, 11:00 PM Thread Starter
Ok so I did a EGR delete on my 6.0 best idea ever, but now the damn engine light keeps coming on. I have the edge tuner so I can clear it nice and easy but I just want the light to stop coming on for it does anyone know how to disable the EGR system check?
Happy Friday guys and gals
DieselMan is offline
post #2 of 8 (permalink) Old 05-26-2012, 11:16 AM
Don't quote me here, but I think the SCT tuner is the only one that will get rid of that light.
post #3 of 8 (permalink) Old 05-26-2012, 11:52 AM
dont know about diesels. but in know in the lightning world when you remove the egr and the light comes on. you need to get it turned off in your tune. Dont know if your running a tune. that should help.
or keep turning it off with your device. or stick electrical tape over the light.
last 2 are not the right way to do it even thou its cheap and easy
post #4 of 8 (permalink) Old 05-26-2012, 11:12 PM
SCT is the only way I have heard of.
post #5 of 8 (permalink) Old 05-27-2012, 12:55 AM
also heard this about the sct
post #6 of 8 (permalink) Old 06-09-2012, 09:57 PM
Hillz's Avatar
Sct is the way! I recently drove a Duramax with a edge juice. Does not compare to my X3 with custom tunes.
2005 F250 SCSB 4x4
-ARP studs, PowerMax turbo, Custom tuned SCT, Accufab intake elbow, Coolant filter, Oil bypass filter, Autometers and Scangauge, Zoodad + fast idle mods, Gogo direct solenoid, 4" turbo back MagnaFlow duals,2.5 levelling kit, Air bag helpers, Cowl hood, 7.5` Arctic plow
Hillz is offline
post #7 of 8 (permalink) Old 12-08-2012, 08:37 AM
Mechanic
you could remove the bulb ?
itsakeeper is offline
post #8 of 8 (permalink) Old 12-10-2012, 08:28 AM
sct and h&s are the only tuners that can turn off any egr codes unless you have custome tune made.. but sct is probably the cheaper way to go...
powerchoke is offline
EGR Delete-Sort Of HTRDDSL Alberta 6 08-30-2011 02:27 PM
engine light came on gilligan F-150 1997 to 2003 /04 Heritage Forum 4 06-30-2011 01:53 AM
Check Engine light Fordwheeler F-150 1997 to 2003 /04 Heritage Forum 4 03-19-2011 10:27 PM
Anyone done the EGR delete thing to their 6.0 yet? Fordsforever6.0 Super Duty Forum 13 05-20-2009 06:01 PM
engine light on...help!! lightning25 Gas Engines 8 10-18-2007 10:21 PM
