Bad timing - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 07-30-2012, 05:00 PM Thread Starter
Bad timing
With 5 days before I start holidays my 2006 f250 5.4 L with 204147 km had the check enging light came on so I borrowed a code reader and the code is p0352 ignition coil b primary/secondary , was wondering if anybody can steer me in the right direction to fix this problem. thanks for any help you might be able to offer.
kidster is offline
post #2 of 5 (permalink) Old 07-30-2012, 07:02 PM
welcome to fordtough.ca, sorry to hear about the tough luck, but hopefully you'll be 100% before your vacation starts.
No mechanic, but I'd suggest finding ignition coil b and replacing it, or checking it out at the least.
What issues have you had with the truck since it threw the code ??
Might be easier to diagnose the problem if you gave an idea of how it was running after the problem occurred......
post #3 of 5 (permalink) Old 07-30-2012, 07:46 PM
What SVT said, but I'd disconnect the coil pack first, clean the connections (and put some dielectric grease on them), reconnect, clear the code, and see if it comes back. It may be that simple?
Or not.
post #4 of 5 (permalink) Old 07-31-2012, 06:35 PM
Or not.
x2 My suggestion would have been to check the screws holding the coils down for dirt/corrosion. Then check the electrical connections.
post #5 of 5 (permalink) Old 08-01-2012, 08:11 PM Thread Starter
Thanks , I was trying to change the plugs but can't figure out how to get the dust cover off to gain access to remove the spark plugs. Thanks for all the help.
kidster is offline
Bad Brakes.Bad design! canuck 1 Super Duty Forum 8 03-21-2010 05:26 PM
NEED HELP: timing? misfire issue? Hammermill97 F-150 2004 to 2008 Forum 6 09-25-2009 10:39 PM
Did the Timing Chain issue get resolved? Maritime Storm Ranger Forum 2 07-21-2009 01:31 AM
Timing out trying to post in classifieds BMac FordTough.ca Site Help? 6 04-13-2009 06:10 PM
Edge chip and timing wayner147 F-150 2004 to 2008 Forum 0 04-10-2009 10:58 AM
