Help: Rad leak? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 06-03-2013, 09:16 PM Thread Starter
Help: Rad leak?
2008 F350 6.4 Diesel
Truck was dripping coolant and it was coming down in the driver side wheelwell area. Leaks from engine compartment down the fram e and drips off just behind the tow hook. It was doing this for about 3 weeks. I was adding small amounts of coolant to keep it topped up.
Now that I have some time I was going to search for the leak. Well it stopped leaking. Sweet. I dont trust it for the couple of long road trips I have in the next few weeks.
Rad? Upper hose? something else? Do I just bite the bullet and replace the rad?
TeamGreen is offline
post #2 of 3 (permalink) Old 06-03-2013, 11:21 PM
through some coolant leak dye in there. when it starts leaking you can find out where it's coming from.
I know it's not leaking right now, so why drop a bunch of money on something that might not be the issue.. ?
post #3 of 3 (permalink) Old 06-03-2013, 11:39 PM Thread Starter
Thanks.
I dropped it at the local diesel mechanic. Hopefully a pressure test reveals something. I find it odd it stopped leaking.
lower rad support fordman F-150 1997 to 2003 /04 Heritage Forum 1 07-24-2012 04:12 AM
Rad Support Mounting Hardware?? taisa899 Exterior 13 05-11-2012 02:37 AM
rad hose $304.95 plus tax gilligan Other Ford Models 10 04-18-2012 10:41 PM
Pink Rad anti freeze Bruicer F-150 1997 to 2003 /04 Heritage Forum 18 02-20-2009 12:24 AM
