2010 F-350 King Ranch Clunk Under Driverseat - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 10-08-2014, 05:01 PM Thread Starter
I have a 2010 F-350 King Ranch with around 70 000km on it and there is a clunk under the truck when driving highway speed and hitting a bump on the road or even at low speeds when I hit a big bump it will clunk. This is starting to drive me nuts had it at a ford dealer and a local mechanic nobody can find anything wrong with it. They have checked the front end and everything is tight. Has anyone else had this issue? Also if I grab the rear tire and rock it back and forth as hard as I can it will make a clunking noise in the rear end but not as loud as when I am driving down the highway. If anyone can help out I would appreciate it.
ford08 is offline
post #2 of 4 (permalink) Old 10-08-2014, 07:23 PM
Start with looking at bushings, links, u-joints and hanger bearings. The F-550 just bent a front stabilzer bolt that came loose and made a similar noise. Are the spring shackles touching down on the frame? Just some suggestions to start with.
post #3 of 4 (permalink) Old 11-25-2014, 06:21 AM
Crazy_Canuck's Avatar
There was a tb on cab mounts a couple years back something about incorrect washer installation can cause the problem you are describing.
2011 F350 Dually PSD CC Lariat ultimate still stock
y2k x cab 4x4, with a few extras. broke Feb 2011 collision
Crazy_Canuck is offline
post #4 of 4 (permalink) Old 11-28-2014, 04:52 PM Thread Starter
I had it at the dealer for an oil change got them to drive it they said they don't hear anything out of the ordinary. They told me about the cab mount service bulletin there just from what I explained to them so I might get them to look into that. I was out hunting with some buddies and it's embarrassing when we are out down the back roads and its clunking around like an old farm truck. Pretty sad when my buddies dodge a 1 ton rides smoother and quieter.
ford08 is offline
02 King Ranch Chucko2929 Photo and Video Gallery - Members Rides 6 04-15-2012 12:49 AM
King Ranch Leather cracking TeamGreen Raptor, Harley-Davidson, Limited, King Ranch, 60th Anniversary, Platinum 4 03-28-2011 04:04 AM
how do you clean king ranch leathers? Fukenricen Raptor, Harley-Davidson, Limited, King Ranch, 60th Anniversary, Platinum 3 03-27-2011 10:29 PM
2010 King Ranch Blue Oval Wheels and Tires 0 01-29-2010 03:04 PM
Add King Ranch section?? 06KingRanch FordTough.ca Site Help? 6 11-02-2008 06:02 PM
