NEED HELP: No Wipers - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 12 (permalink) Old 10-14-2014, 08:13 PM Thread Starter
Still no wipers
Hey All new to the forum, I have a 2004 ford super duty F350 King Ranch Dually With 6.0L diesel. I try my best at fixing things but FAR from really knowing what I'm doing lol.
Problem I have is my windshield wipers just stopped working. I have checked fuses and they are fine in fact I even changed them to be sure. I used them one day turned on next day nothing fluid not working either. I know small question but is there a relay or do I have to just change wipermotor?
Sharosa is offline
post #2 of 12 (permalink) Old 10-15-2014, 04:23 AM
Welcome to fordtough.ca Iohn, great group of Canadian Ford owners here.
I'm no expert , but right off the top I'd check the switch if you're not getting wipers or the spray.
Motor might be just fine, wouldn't jump to replacing that right away, but that's just me.
post #3 of 12 (permalink) Old 10-15-2014, 05:02 AM
post #4 of 12 (permalink) Old 10-15-2014, 09:17 AM
Like others said. Start at the switch and work your way out.
post #5 of 12 (permalink) Old 10-15-2014, 08:05 PM Thread Starter
thanks will do so tomorrow..
Sharosa is offline
post #6 of 12 (permalink) Old 10-18-2014, 01:41 PM Thread Starter
had switch checked it was fine. I purchased new wiper motor installed it still dead. There are 3 banks of modules behind battery and drivers side firewall. I cannot find anything that tells me what those relays are. Anyone have any idea? I have picture but cannot upload
Sharosa is offline
post #7 of 12 (permalink) Old 10-18-2014, 02:23 PM
I'll bet the wiper motor was reasonably priced.
I threw in my two cents with the switch, after that your guess is as good as mine, good luck with that, electrical gremlins are the best.
post #8 of 12 (permalink) Old 10-19-2014, 07:50 AM
Wiper control module, if it has one. Power relays, check fuses with a meter. Disconnected plug? Anything else not working?
post #9 of 12 (permalink) Old 10-19-2014, 10:29 AM Thread Starter
Originally worked one day next day nothing washer fluid does not work either. I have replaced the wiper motor, I have metered fuses, I was told by ford that relays are in motor as it is a 12 wire harness going into wiper motor, I have disassembled signal/wiper/high bean switch and cleaned out old grease and reassembled. I have metered that there is 11.7 volts getting to the wiper motor and there us an extremely faint click when I turn wiper switch on. Signals work, high beams work, 4 ways work. again I have found 3 banks of relays between battery and drivers side firewall and cannot find any information what they are.
Sharosa is offline
post #10 of 12 (permalink) Old 10-22-2014, 07:40 PM Thread Starter
Well now I am in a pickle I hope someone will have the answer. I know wipers are not the most interesting thing to help with but please....
As of now I have checked all fuses and replaced them, I have changed the wiper motor and now just finished changing the switch still nothing. If anyone has anything please help. Thanks in advance.
John
Sharosa is offline
Wipers wont shut off 9Lives F-150 2009 to 2014 Forum 7 04-13-2015 04:09 AM
Wipers Stopped Working herbz F-150 2004 to 2008 Forum 8 04-15-2011 01:46 PM
NEED HELP: windshield wipers Slasher Exterior 8 07-13-2009 08:47 PM
'02 f350 wipers and washer no worky Loadedagain Super Duty Forum 17 04-15-2009 08:34 PM
Opinions wanted for Wipers Matty Ranger Forum 19 01-19-2009 09:29 AM
