Rev x - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 01-20-2015, 10:03 AM Thread Starter
Rev x
Any 6 litre guys out there using REV X oil additive or fuel additive? I have been using the oil additive and it works wonders for injector stiction.
www.misenermotorsports.com
Dealer for SCT, UPR, TFS, Rough Country, Rev X ETC
Mise is offline
post #2 of 10 (permalink) Old 01-20-2015, 10:33 AM
I've heard it works good, but don't use it myself. With the mods I have, the oil stays clean and I don't have stiction issues. I would use if I had to though!
post #3 of 10 (permalink) Old 01-20-2015, 11:33 AM
zip
zip's Avatar
I have used it a couple times. That and Hotshots Secret. Many have had success with it and it's readily available. There is some other stuff out there called Archoil. I think that's how it's spelled. I may try that.
Chris
75 F150, 79 Bronco
zip is offline
post #4 of 10 (permalink) Old 01-20-2015, 11:41 AM
Canadian Bacon's Avatar
Is that the stuff that you have to pour into the HPOP first? My dad uses Hotshots in his 6.0L so far so good.
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #5 of 10 (permalink) Old 01-20-2015, 03:23 PM Thread Starter
Yes its best to pour it under the oil filter housing so I have been told
Mise is offline
post #6 of 10 (permalink) Old 02-24-2016, 09:06 PM
Archoil
I,ve been using Archoil for a while now. The first time I used it, I poured it directly into the filter housing but removed the center of the housing first. The part you push your oil filter onto comes out easily with one torx bolt. T27 if i remember. I used 16oz on the initial treatment. WOW. what a difference, runs way smoother and quieter. Now I just use 8oz every oil change and pour it in with the oil. (Amsoil Series 3000 5w30) Just order Archoil on Amazon and it ships right to your door. I really recommend this stuff. I have 250,000 km on my original injectors now and am not having any issues at all. Try it, I don't think you'll be disappointed.
Allen 6oh is offline
post #7 of 10 (permalink) Old 02-24-2016, 11:27 PM
zip
zip's Avatar
I want to try some of that. No issues at this point. I know there is a dealer for the stuff in Edmonton and I will be in that area in June. I should call and see if it is an item they keep in stock.
Chris
75 F150, 79 Bronco
zip is offline
post #8 of 10 (permalink) Old 02-25-2016, 09:29 PM
I have also bought the Archoil AR9100 here before -
4 Wheel Auto
8807-63 Avenue
Edmonton, AB T6E 0E9
Phone: 780-468-2570
post #9 of 10 (permalink) Old 02-25-2016, 10:39 PM
zip
zip's Avatar
That is the one I was thinking of. I think they have two stores in Edmonton.
Do you know if they actually have the stuff in stock?
Chris
75 F150, 79 Bronco
zip is offline
post #10 of 10 (permalink) Old 02-28-2016, 03:42 PM
zip
zip's Avatar
I may have found a place a little more local to get some. I will find out most likely on Tuesday afternoon.
Chris
75 F150, 79 Bronco
zip is offline
