warranty suggestions - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 02-19-2015, 04:48 PM Thread Starter
djb
Lightbulb warranty suggestions
hello all,
anyone have suggestions on what to get checked out under a 60,000km warranty before it rolls over.
2012 f250 crew.
djb is offline
post #2 of 3 (permalink) Old 02-19-2015, 04:55 PM
Mechanically I'm not up on my Super Duty trucks.
I'd check on the little finicky things. Things like door switches, heater/AC controls and the little annoying electrical things that can stop working as the truck ages.
post #3 of 3 (permalink) Old 03-06-2015, 10:55 PM
All of the expensive stuff is covered by the 100 000 km (160 k diesel) powertrain.
6.2 gas is generally bullet proof. I fix the odd transfer case - either the synchro assy wears or the overrunning clutch grenades. Otherwise the most common complaint is lack of auto locking 4x4 hubs, which usually is pinned back to ripped off vacuum lines and the consequent degradation of hub seals, check valves and control solenoid. The 6.7 is the same thing except the powertrain components are covered up to 160 000. And if you have an oil burner then I'm sure you've done the SCR heater by now.
Everything that I've mentioned is all covered past 60 000 km. The small stuff that can come up is otherwise dealt with on a case by case basis and doesn't really warrant the label of 'pattern replacement'.
Varsity Tyler is offline
Suggestions for a new mechanic Maverick_Brittany F-150 2004 to 2008 Forum 4 11-23-2009 05:59 PM
Meet suggestions! Smokefan Ontario 30 04-28-2007 02:05 AM
