2011 F250 6.2L Hesitation - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 08-07-2015, 10:57 AM Thread Starter
Recently purchased a 2011 F250 with the 6.2L gas engine.
After filling up with gas I pulled onto the road and the truck faltered as if it was out of gas, then picked up and carried on. Any thoughts on this and should I be concerned?
oldpaintguy is offline
post #2 of 7 (permalink) Old 08-07-2015, 11:51 AM
Welcome to fordtough.ca! I'm no expert, but start simple and maybe replace the fuel filter.
Another thing I've has personal experience with is a little bit of water in the gas, throw in a bottle of gas line antifreeze and see if that helps any, could be a crappy tank of gas.
Its not for everyone, (check the owners manual to see if your trucks computer is tuned for it), but personally, I've had two 6.2L engines, and both have run better on premium.
But then, the Raptor is tuned for premium, if you're not tuned for premium, its a waste of money.
Good luck and welcome, I lived in Peterborough for 8 months while I was going to Trent University, beautiful little spot.
post #3 of 7 (permalink) Old 08-07-2015, 03:43 PM Thread Starter
Thanks for the reply.
Will try the gas line antifreeze tonight.
I thought I read this truck had a permanent fuel filter?
post #4 of 7 (permalink) Old 08-07-2015, 04:38 PM
Canadian Bacon's Avatar
Welcome.
What gas station did you fill up at? How low was it before filling? How many KMs? Any maintenance records?
Your truck doesn't have a replaceable fuel filter.
If you want to start simple and cheap try Amsoil P.I. LINK. I wouldn't recommend it if I didn't use it personally and notice a difference.
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #5 of 7 (permalink) Old 08-07-2015, 06:05 PM Thread Starter
Has 160,000 km on it. Had 1/4 tank when I filled up at Canadian Tire. Bought private, unfortunately no maintenance records.
This was a one time occurrence so far. Only had the truck 9 days, and put 200 km on it. It faltered then picked up and drove fine. Drove fine prior to this.
post #6 of 7 (permalink) Old 08-07-2015, 06:13 PM
Well there you go, I warned you I wasn't an expert. lol
I always fill up at CTC, not sure who their supplier is, personally never had any issues, but that doesn't mean anything.
Amsoil is good stuff, I'll have to add the PI to the list.
Last edited by SVT4MT; 08-08-2015 at 03:35 PM. Reason: wow was there a lot of typos and awkward sentence structure.
post #7 of 7 (permalink) Old 08-08-2015, 01:05 PM
160k is usually when Ford recommends changing the plugs, you may want to pull one out and see what they are like, but I'm not sure if that is correct for the 6.2L because I think it's a dual plug design.
Usually Crappy Tire is pretty good for gas, my FIL fills up at Crappy tire every week, so as long as it wasn't President's Choice or no name gas it should be fine.
Other than P.I. and a plug change I'm not sure what else to recommend. It could be something you have to wait to see if it does more frequently and throws a code.
Amsoil Home Page
2011 F250 4x4 problems Roadwarrior Super Duty Forum 4 12-06-2014 11:52 PM
NEED HELP: 2011 F250 diesel Bull_Auger Super Duty Forum 11 09-12-2010 09:33 PM
Hesitation and HVAC issue Redstuff F-150 2004 to 2008 Forum 3 05-02-2010 02:14 PM
NEED HELP: 2006 6.0L Hesitation Brocktoones Super Duty Forum 4 06-13-2009 10:53 PM
