wind and road noise mod - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 03-23-2008, 01:56 PM Thread Starter
dieselpower's Avatar
Got this fix from another super duty site.Bought 50 feet of 3/8" OD latex tubing from www.smallparts.com $16.65 per 25 feet.Fish tubing through your weather stripping around your door sills.Makes the door close a little snugger but will seal door just enough to make a tight seal.I have a 2000 F250 super cab
dieselpower is offline
post #2 of 8 (permalink) Old 03-23-2008, 02:11 PM
Welcome to FordTough.ca! I have an 06 250 for my work truck I might try that cause my driver's door is a little noisy
post #3 of 8 (permalink) Old 03-23-2008, 02:30 PM
Welcome to fordtough and thanks for the great info
post #4 of 8 (permalink) Old 03-23-2008, 09:13 PM
Great tip! I might try this, thanks.
Lightning Steve is offline
post #5 of 8 (permalink) Old 04-03-2008, 06:13 PM
mechanix61's Avatar
you can buy that tube at any home depot, great Idea .
mechanix61 is offline
post #6 of 8 (permalink) Old 04-03-2008, 07:12 PM
Welcome to FordTough. That sounds like it might be a great little fix. Maybe even for 1/2 back doors on super cab.
post #7 of 8 (permalink) Old 05-29-2008, 08:13 PM
I did my truck several years ago. I did both the back and front seals, and between the front and back doors. At the time the hose of choice was plain 3/8 OD clear plastic. It works fine for me, but I could see trouble in colder climes. Probably the easiest way is to take off the weather stripping and lay it out straight. A fish would work best, but talc or WD40 also will work. There are some plugs near the bottom of the weather stripping that have to be removed as well. I believe the end result is worth the effort.
jerry
Totem is offline
post #8 of 8 (permalink) Old 05-30-2008, 09:31 AM
Chris.S.'s Avatar
Sounds like a good trick!
I've been surprised at how noisy my doors are since the day I bought the truck...
Chris.S. is offline
NEED HELP: Whining noise on cold start up Chuck P Gas Engines 32 12-17-2009 11:15 PM
NEED HELP: LOUD vibration type noise RichmondRanger Ranger Forum 6 10-11-2008 09:52 AM
front end noise help mud flies Ranger Forum 5 08-10-2008 08:59 AM
engine noise on start up??? silverfox Gas Engines 14 09-24-2007 10:50 PM
