285/75/16 Tires - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 05-26-2016, 08:48 PM Thread Starter
285/75/16 Tires
Hi All, new to the forum and an F350. I would like to go with 285s on my F350 4x4. Has anyone done this with the stock aluminum outer and steel inner rim. Will they touch. I might go with 17s on aftermarket wheels. I am trying to get the rpm down on the hwy.
Thanks Brian
Jake62NHRA is offline
post #2 of 3 (permalink) Old 05-27-2016, 09:31 AM
Canadian Bacon's Avatar
Hi Jake welcome to Ford Tough! Unfortunately never owned a Dually so I can't help you much. Can you tell us a little about your drag car?
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #3 of 3 (permalink) Old 05-30-2016, 03:15 PM
zip
zip's Avatar
Welcome Jake. I don't know what year you have and can't say anything about the aluminum outer and steel inner rim. I have an 03 with the stock aluminum wheels which I mounted 258/75/16 tires on. That size was pretty much as much tire as I wanted to put on that sized wheel. There was no rubbing or nasty side effects. I now run a 35" tire on a 18" wheel.
Chris
75 F150, 79 Bronco
zip is offline
NEED HELP: Tires: It's time for me to change the tires... WHICH ONES? will99 Super Duty Forum 6 04-11-2013 10:30 AM
lt 285/70/17s on a 3.55 cdnarmyguy Wheels and Tires 6 11-16-2011 09:51 AM
NEED HELP: tires 1BAD4D F-150 2004 to 2008 Forum 5 01-10-2011 09:06 AM
285/70/17 Ford00XLT Wheels and Tires 2 04-03-2010 01:19 PM
