Cam phaser problem. - Page 2 - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 2Likes
post #11 of 18 (permalink) Old 12-23-2018, 11:03 AM
I like Fords Too's Avatar
I've got an '01 f150 with a 5.4
no problems other than the loose plug deal , once
and I just had to put an alternator on it
- it does seem to have a little piston slap now when really cold until warmed up some
at 350850 km's
my 95 merc with a 4.6 went 580 000 km's without anything other than an alternator too
only reason it went to the scrapyard was I had the truck too and didn't need the rusty old merc
however I too would avoid any 4.6 or 5.4 build after 03 .. yep the ones that got the phasers
and the problematic two piece plugs
- you know about THOSE ?
I like Fords Too is offline
post #12 of 18 (permalink) Old 12-24-2018, 11:54 PM
My 04 runs good. Biggest problem with phasers is people who run too long between oil changes and oil is dirty. I run synthetic oil and change every 5-6000km.
If you use a 1/2 inch drive impact and try to run the plugs out in one shot they will break. Use Ford's proceedure and usually no problem. The new plugs are not two piece.
SKRWZ likes this.
post #13 of 18 (permalink) Old 12-28-2018, 01:47 PM
thinkin' , I seem to remember finding a cam phaser eliminator kit or some such
might be worth some research too
post #14 of 18 (permalink) Old 12-28-2018, 05:18 PM
Yes, it's under the name "351 Windsor."
post #15 of 18 (permalink) Old 12-29-2018, 02:21 PM
Cam on, I resisted as long as I could.....but resistance...is.....futile.
post #16 of 18 (permalink) Old 12-29-2018, 06:50 PM
six doesn't like seven
because seven eight nine
post #17 of 18 (permalink) Old 12-31-2018, 12:45 PM Thread Starter
Are you sure its piston slap you're hearing. Rattle on start up is common with the cam phaser problems and, at that stage, could start doing some serious damage to cam shafts and journals or valves and pistons. Yes you can maybe prevent an issue with cam phasers with regular oil changes and you can get a lock out kit for it. The lock out doesn't help you much if the damage is already done. And you have to get an aftermarket tuner so your computer doesn't think something's wrong. If you talk to an honest tech at the ford dealer they'll tell you to avoid the 5.4. They see alot of them in the shop. I've always been a ford guy but trying to buy a 3/4 ton truck in my price range ( I'd like to keep it around $15,000), and not buy something with over 200000 km, and avoid the 5.4l, is hard. F-250's with the triton seem to be the cheapest for sale in their class. Maybe for a reason. Only other option for ford is deisle. If the 6.0l is problematic then the good old 7.3l is the only option that makes sense. People want alot of money for them. I see alot for sale for $15,000 ish with 350000km +.
06superdirty5.4 is offline
post #18 of 18 (permalink) Old 12-31-2018, 01:18 PM Thread Starter
Sorry I see now that your 5.4 with the piston slap sound is 01 and phasers weren't put in until 04 I think.
Mrmagoo likes this.
NEED HELP: Phaser/timing issues ElectroVeeDub F-150 2009 to 2014 Forum 0 07-20-2016 12:37 PM
NEED HELP: Cam Phasers Alberta F150 F-150 2004 to 2008 Forum 32 03-10-2014 10:37 PM
Cam sensor positioning tool TRUKNUT Gas Engines 3 11-17-2013 04:45 PM
NEED HELP: back up cam problems hooduu F-150 2009 to 2014 Forum 7 04-24-2012 10:27 PM
