Cam phaser problem. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 2Likes
post #1 of 18 (permalink) Old 12-05-2018, 09:20 PM Thread Starter
Cam phazer
Hey I'm new to this forum. I have 2006 f250 superduty with a 5.4l. Just bought it and now I'm hearing a knocking sound almost like a quiet deisle. From what I hear its probably cam phazer issues. Anyone have this done and how much did it cost to fix?
06superdirty5.4 is offline
post #2 of 18 (permalink) Old 12-08-2018, 12:14 AM Thread Starter
Cam phaser problem.
Hi everyone! Last weekend I bought a 2006 f-250 s/d with 5.4l from a used car lot. I didn't notice when I test drove it but on the way home with it I noticed, at idle, it made a knocking sound. I took to Google and read about all the horror stories regarding the cam phaser issue. Some people said this noise was normal and others said it's most certainly not. I phoned ford and they said if it's not running really rough that its probably a normal noise. I had noticed a slight misfire when underload in overdrive (at first I thought that was just a bad coil over plug) so I decided to take it to a friend that works at ford. He said get it in right away. So I made the appointment with him and it went in today. Turns out it's the cam phasers (big surprise) and the vct solenoid. Quoted me $3600 to fix. So I'll be going to the place i bought it tomorrow to see what they will do, but with no warranty I'm worried they wont do anything. Was super excited to get a 3/4 thats newer ( I've never had anything but early 90s f150s) but now I'm not feeling so good about my purchase. Any thoughts?
post #3 of 18 (permalink) Old 12-08-2018, 06:03 AM
The only, albeit not very helpful, suggestion I have is get rid of it and procure a pre-1997 F-250 or F-350. Parts are cheaper and in most cases easier to get. If the quote is just for one head, you can pretty much guarantee the other head isn't far behind.
post #4 of 18 (permalink) Old 12-08-2018, 12:28 PM Thread Starter
The $3600 quote includes both phasers, tensioners, vct solenoids and everything else related to the timing system except the chain its self because he says the chain is usually fine. They said that the phasers and solenoids are the problem and its likely that the rest of needs replacing but they wont know for sure until they actually remove the valve covers. I cant see having it apart and not doing the guides/tensioners and what not. To get rid of it, unless the dealer I bought it from buys if back from me for what I paid for it (not happening), I'm looking at a loss in value at least the cost of the fix because I wont unload it on someone else, like me, who was ignorant to the issue. I appreciate the response but you're right its not much help.
post #5 of 18 (permalink) Old 12-09-2018, 03:08 PM
You are experiencing a very common issue with 5.4L 3V engines, which I'm sure you've found out.
I'd talk to the place you bought it from before you dump money in it. If they won't help you I guess all you can do is fix it. The things your mechanic wants to do seem reasonable and the price isn't crazy.
post #6 of 18 (permalink) Old 12-09-2018, 10:35 PM Thread Starter
Thanks. I went and saw the sales person where I bought it, the owner was on holidays, he did phone the owner and he said he would have it done at the private shop he used for half of fords quote and split that bill in half with me. I told the sales guy that I didn't want any aftermarket parts and I wanted all fords part numbers. He said he would have to call the boss back later and call me around 5:00. He didn't call me back. So I went back to the place, it was closed and all locked up with nobody there. I called an after hours number that was written on the door and got the owner. He still wanted his shop to do the work and if I wanted ford parts I would have to pay the upcharge. I said no. I said I would split fords quote with him because I was more comfortable having them do it and warranty the repair and parts. He agreed to that. Not ideal that I have to pay another $1800 but I'm glad it'll be done.
post #7 of 18 (permalink) Old 12-16-2018, 01:41 AM Thread Starter
Thought I'd though an update out there. My f-250 went into ford for the timing system repair and sure enough more problems. Cam shafts and journals and what ever else that raised the bill to almost 7 grand or a new motor for 10 installed. Lucky for me the place I bought it from just gave me my money back. So looking for a truck again. Any suggestions on engines in F-250 or f-350? I'd rather stick with a ford but my options where I am are limited in 3/4 ton and 1 ton trucks in my price range. I'll be buying something in the range of 2000 -2010. Newer then that is more then I want to spend on a work truck / hunting truck. Any older and it has high km or is rusted out.
post #8 of 18 (permalink) Old 12-16-2018, 11:09 AM
Honestly I’d look for a diesel super duty. If you can get something newer, a truck with the 6.2 V8 would be better than a 5.4.
post #9 of 18 (permalink) Old 12-16-2018, 01:09 PM Thread Starter
Thanks. I will not be getting another 5.4. Not to say that you can't get a good one but I'm excluding them from my search. A nice f- 350 with a 6.0 deisle is available. I've never owned a deisle and I don't know anything about the 6.0.
post #10 of 18 (permalink) Old 12-16-2018, 06:11 PM
6.0 Diesel is worse than the 5.4 gas. The parts are more expensive. The problems are more extensive. And, Ford doesn't seem to know how to repair them properly.
NEED HELP: Phaser/timing issues ElectroVeeDub F-150 2009 to 2014 Forum 0 07-20-2016 12:37 PM
NEED HELP: Cam Phasers Alberta F150 F-150 2004 to 2008 Forum 32 03-10-2014 10:37 PM
Cam sensor positioning tool TRUKNUT Gas Engines 3 11-17-2013 04:45 PM
NEED HELP: back up cam problems hooduu F-150 2009 to 2014 Forum 7 04-24-2012 10:27 PM
