2010 power steering leak - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 08-08-2019, 11:02 AM Thread Starter
Hey guys..
I have a 2010 super duty 5.4
I noticed the PS pump was whining and fluid was low. I filled the resivor and I have some fluid leaking on driveway.
But doesn't "seem" to be coming from pump or lines.
Is there only 3 areas on pump it could leak ?
Pressure line
Return line
And front seal
Is there any possible leaks behind pump?
Thanks in advance
Hailey is offline
post #2 of 4 (permalink) Old 08-08-2019, 09:38 PM
The power steering cooling loop, if it has one. The steering box or if you have a hydroboost brake setup, it could be the booster but unlikely.
post #3 of 4 (permalink) Old 08-08-2019, 10:03 PM Thread Starter
Thanks for the reply.. doesn't look like it has the hydro boost. I'm going to brake clean it good and inspect again.
Should I run ATF fluid in power steering pump? Thanks again.
Hailey is offline
post #4 of 4 (permalink) Old 08-09-2019, 06:32 AM
I would, but, I'm always thumbing my nose at the engineers.
