Getting Wires from Engine To Cab? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 11-30-2020, 05:08 PM Thread Starter
I have a 2018 F250. I need to get some wires from the grill for strobes through to the cab.
I know there are pass through wires installed, and I have done wiring using these on other trucks easily. However, on my truck, for whatever reason, the factory install of these wires just left little stub ends of the wire that are only about 1" out of the firewall on the inside of the cab (passenger side near floor).
There is NO way I can get in there to solder or crimp; there's just too little wire to work with even if I could contort my body to fit down there.
What are my alternatives? Are there any other pass through options or should I just run the harness under the can and snake through towards the back of the rear seat wall where I know there is some access?
Thanks in advance.
Pete
Retired (with a nasty Metal Fabrication Hobby)
CalgaryPT is offline
