Couple questions - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 19 (permalink) Old 10-03-2008, 04:28 PM Thread Starter
Couple questions
I am trying to figure out the build date of my truck so I can tell if I have an early 99 or a late 99 (there are differences) but that tag that is supposed to be on my drivers side door is not there? I have looked all over the truck and can't seem to find it. Any suggestions?
I did find this tag if that helps.
I am also trying to figure out what front diff I have, D50 or 60? The Dana pn on the axle is 610659 1
I know I have the ford 10.5 rear but I would like to know also if I have LS or open. The rear diff tag reads S-406 8
3.73 10.5 8619
Thanks in advance
post #2 of 19 (permalink) Old 10-03-2008, 04:39 PM
might be some help here
http://www.thedieselstop.com/faq/199...eral-Specs.htm
i would say dana 50. i think the 60 came with the dually. but could be wrong. can't help with the limited slip. maybe jack up rear end and manually spin a tire and see if other goes in opposite direction. if so open diff.
post #3 of 19 (permalink) Old 10-03-2008, 05:32 PM Thread Starter
Thanks I couldn't remember what way the tires turned for open. I have the same question posted over at TDG so I'll try the one you posted if I don't get anywhere.
post #4 of 19 (permalink) Old 10-03-2008, 05:58 PM
Stainless's Avatar
Sean you can just go to a Ford dealer in town and have them run an option list for your vehicle and print it off. You most likely have a Dana 50 in your truck, thats what I had in mine. Oh and they can check for any outstanding recalls while you are there.
Stainless is offline
post #5 of 19 (permalink) Old 10-03-2008, 06:05 PM Thread Starter
If I don't get it figured out today I will do that on Monday, thanks Brad.
post #6 of 19 (permalink) Old 10-03-2008, 06:36 PM Thread Starter
So I found a build date on the driver side valve cover and it states that I have an early 99.
post #7 of 19 (permalink) Old 10-03-2008, 06:50 PM
BMac's Avatar
You would also have a D60, the 250's had the D50 until 2002 where the 350's all came with the D60
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #8 of 19 (permalink) Old 10-03-2008, 07:15 PM Thread Starter
Thanks BMac thats the answer I wanted to hear.
post #9 of 19 (permalink) Old 10-03-2008, 09:20 PM
Stainless's Avatar
Dont use the engine build date as your truck build date, my truck was a late 04 and the engine was a 03. And Bmac was right I was confused about the diff. Hey its been quite a while since I have owned it
post #10 of 19 (permalink) Old 10-04-2008, 03:12 PM
zip
zip's Avatar
Dead giveaways are a smaller track bar (17mm bolts vs 21mm bolts) and the ubolts on the front springs are more rounded across the top. The latter 99's are flat across the top.
Chris
75 F150, 79 Bronco
zip is offline
NEED HELP: Accessory Questions Rustycan Ranger Forum 17 01-03-2009 07:40 PM
Rear Diff questions f150phule Driveline and Transmission 6 11-25-2008 12:59 AM
more newb questions Frumpy F-150 2004 to 2008 Forum 8 03-20-2008 10:35 AM
wheel offset and other questions sicksonicescape Wheels and Tires 1 02-07-2008 09:21 PM
