In order to replace park brake shoes you must first pull rear axle out(remove the 8 bolts) then pull the hub off.You will need a two jaw puller,a step plate(goes on fixed spindle so thread part of puller can push againts it to remove hub and a axle locknut socket.If you plan on keeping your truck I would buy a ford work shop manual mine came in 2 volumes(2 big books)I like books better you can have them right beside you when you work.you can call this number to order right from HELM 1-800-782-4356 these are the same books ford uses they tell you everything i like it because it has all torque specs too well worth the money if you like to do work your self.
