Rims & Rubber - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 13 (permalink) Old 10-16-2008, 07:59 PM Thread Starter
svukovics's Avatar
Rims & Rubber
Heys guys, i'm new here... drive a 2004 superduty and have a question...
I'm looking at upgrading my rims and rubber, looks like i'm driving on pizza cutters at the moment.
Anyways heres my question... I haven't lifted her yet, and not in the means of doing so at this time, so i was wondering if any of you knew what size rim and rubber i could fit in her stock?
thanks guys
svukovics is offline
post #2 of 13 (permalink) Old 10-16-2008, 08:15 PM
Welcome to FordTough.ca
If you are looking for some great rims, I know Blackstock has some brand new HD superduty rims, I don't know if they are the same bolt pattern but you may want to PM Father Patrick on this
post #3 of 13 (permalink) Old 10-16-2008, 09:28 PM
zip
zip's Avatar
A 285/75/16 fits quite nicely on the stock wheels if your stock size is a 16". That's what I had before the leveling kit. Matter of fact that is what I still have.
Chris
75 F150, 79 Bronco
zip is offline
post #4 of 13 (permalink) Old 10-16-2008, 10:04 PM
Stainless's Avatar
I had the same size as listed above, really cant go much bigger with out cutouts.
Stainless is offline
post #5 of 13 (permalink) Old 10-16-2008, 10:56 PM
I have the same as above too on the F250, 285's look good on stock trucks with no rubbing at all and they don't look stuffed in there on a Super Duty
post #6 of 13 (permalink) Old 10-17-2008, 12:19 AM
I went to a 285/70 r18 on my 99f-250 sd with no problems,some guys out here running up to a 305/65r18 with just a spacer block on front.
post #7 of 13 (permalink) Old 10-23-2008, 12:01 AM
Sicksoh's Avatar
I am running 35x12.50r18;s on the stock rim no lift
2006 PSD CC FX4 Sport SRW S/B
Sicksoh is offline
post #8 of 13 (permalink) Old 10-23-2008, 02:14 AM
BMac's Avatar
You have a bit more room, the coils have a little more height then the 04 down with the leafs up front
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #9 of 13 (permalink) Old 10-23-2008, 11:16 AM
Sicksoh's Avatar
Thats what I figured but thought I would throw my 2 cents in there
Sicksoh is offline
post #10 of 13 (permalink) Old 10-23-2008, 11:39 AM
WTF I was told by Ford I need 4" lift to clear the 35's without cutouts, did the diesels come with different suspensions then the 5.4L Super Duty's mine is an 06. Do you ever get any rubbing when the truck is flexing while moving, going over curbs or into washouts.....
I already have a Level Kit and 4in blocks on the back of the 250
Halloween Drive & Drag & TMP - OCT 31 TMPracing Ontario 0 10-07-2008 01:42 PM
B 4 this winter I'll need new rubber... 4X4 EH Wheels and Tires 6 08-17-2008 07:19 PM
MEET/G2G: Ford & Mercury Truck Nationals- August 16th & 17th.08 fordtough.ca Ontario 7 08-06-2008 09:11 AM
New rubber Holdfast Ranger Forum 0 07-01-2008 11:12 PM
20" tires - what rubber to get? 4X4 EH Wheels and Tires 10 01-31-2008 09:55 PM
